Results 1 to 25 of 30
    Default 3.8L V6 Random Stalling While Driving Restart After Cool Down
    The end of last summer we took our '85 LTD wagon up north on vacation. It was still reasonably hot during the trip even though it was late in the season. It is about a six hour ride back and forth.
    On the way up the car ran fine as well as while we were up north. Coming back down after driving for about 2-3 hours going down the highway the car just stalled and quit (of course this is while my wife, son, dog, and MIL are in the car with all of our stuff). After doing a cursory check under the hood I didn't see anything obvious. I did have fuel at the CFI, but what pressure I do not know. The car would turn over just fine, but it wouldn't start. As any good person driving a Ford with TFI I had a spare ignition module which I installed. No dice. With the limited tools I had it appeared I wasn't getting spark. Wife and son walk to the gas station down the street while I ponder my next move. After checking a few more things I have my MIL crank the engine while I check something and it starts up (this is after about 20 minutes or so). Elated I go pick up my wife and son and we get back on the road.
    Everything is going fine and then about 1 hour later the same thing happens. Pull off the road and same thing. Again after sitting for a while it starts back up. Since changing the TFI module seemingly had no effect I then focused on the coil. I located one at a parts store and swapped it out. Ran fine. After this it was getting dark and cooling down. Another two hours of driving and just as we are getting off the highway by our house it stalls again. Again same thing won't restart until sitting for a while.
    Sooo, since it is hard to diagnose a problem when it is so hard to recreate I am about at the point where I am willing to just throw parts at it (as if I weren't already there). My next step was to replace the distributor pickup coil unless anyone has any other suggestions. Clearly something is getting hot, failing, cooling down, and then resumes working. Definitely sounds like an electrical component to me. Since I had fuel at the CFI (again could only check for fuel not the actual pressure) I am assuming the fuel pump(s) are okay. Yes I realize that new parts (ignition module and coil) can be bad, but changing them didn't really seem to change anything.
    This engine will eventually be replaced so I don't want to go crazy, but it needs to provide a couple more years of reliable service before that happens.
    '97 Thunderbird
    I would suspect the pickup in the distributor. You can pick up a reman distributor pretty cheap at the mcparts store. I just got one at NAPA the other day for $51, iirc. Or someone on here is sure to have a good used one lying around. Or you can pull yours apart and replace the pickup. I think you will need to press the gear on and off. I would try and find a good used one from a member here, since you're planning on replacing the engine in the near future. I have one or two lying around I would give you, but for the life of me, I can't find them. It was easier for me to pick up one from the parts store than dig them out lol
    St. Louis, MO.
    Could still be the TFI. I went through 3 TFI's till I finally put it on the fender apron with relocation kit. Worst thing Ford ever did was place the TFI's on the dizzy.
    Scotty
    Past Pony's.....
    True. I bought one at the parts store and it was bad. They argued with me and told me I was crazy, after they bench tested it and it showed ok. Drove me nuts. I tested and retested everything, then just started replacing parts. My tests kept pointing back to the tfi. Finally, I took it to another store and they bench tested it again. It showed good, so I had them run the test a few times in a row and it failed. They finally apologized and grabbed another one off the shelf. It was bad. They had 3 in stock and none were usable. So yeah, don't rule out the module! Have them bench tested at the store and go from there.
    I appreciate the input. The TFI module I had was just a cheap Chinese version that I picked up just to have a spare so it could be bad. The only thing that makes me think it isn't TFI related is the first time it quit. I put the replacement module in and nothing changed. It wasn't until after the car cooled down that it started up again. I would think if it were the TFI module and the new one was bad that it wouldn't have started back up at all. That said I may invest in a Motorcraft module although from what I have read they might not be any better than the cheap aftermarket modules anymore. Looking around some more I also see Accel, MSD, and Pertronix units probably aren't any better either. I'd be willing to pay the money for a quality unit if one could be had. That said, what could be so complicated about these that makes it so hard to build a good one? I've never had an ignition module tested in a store, but I have heard that they should test it multiple times to make sure it heats up enough to replicate actually running on the car.
    I appreciate the offer on the distributor. Since I am cheap AND I enjoy the challenge I'll probably tear mine apart to replace the pickup. It looks like you can get a Motorcraft replacement for about $25.
    '97 Thunderbird
    St. Louis, MO.
    My first TFI replacement did the same thing. After it cooled down it started and would bench test fine. They say that the heat absorbing grease should take care of the heat but it did not. Every time it got to hot it would cut off but after a cool down, started right up. So I got a relocate kit and put a Ford TFI module and it works great. I also did replace the dizzy with a new one.
    Ford even started putting the TFI on the apron after to many complaints.
    Scotty
    Past Pony's.....
    Thing is when prob first showed up. Happen before or on trip?
    It is hard to diagnose being intermittent.
    Will never forget similar storys.
    One is humbled badly when car quits way out there in BFE.
    It was what got me interested in carburetors as a 9-10y old.
    Going up north. Taquam. Falls, Alpena. Summer.
    1962 1963?. Family trip. No record of year.
    1961 Chevy Impala 2 door almond beige 283 2bbl powerglide dad bought new.
    Ran fine going up to falls. Came back down. Stayed overnite in Alpena.
    Tanked up. Bought bad gas. Dirty. Prob dont sell much up there.
    Anyway, started stalling out just as yours.
    Dad had to get out the rubber mallet and tapped the carb when car conked out.
    Then it would start and run for 50-100 miles. Pinconning, Bay City, Flint.
    Car was taken to grampa's old neighborhood mechanic Harley Ferguson, in Detroit.
    He disassembled the carb and cleaned it. They let me watch.
    Remember Harley said "dirt in carb".
    Dad said it must have been the gas bought in Alpena.
    Same deal with me.
    1970 VW, 1970's trip to Chicago from Detroit.
    Destination: JC Whitney warehouse to exchange leaking tube header set.
    Coming back, tanked up at a truck stop. Bad fuel.
    Engine stalled on ramp getting back onto I-94 eastbound.
    Smelled diesel out exhaust. Absolutely did not use the truck stop diesel pumps.
    Tow, tune up (unneeded, did it pre-trip). Insisted on draining fuel tank. Good to go.
    So may be a fuel prob. Bad load. Water, dirt.
    Fuel filter, etc.
    Would not hurt to change dist. Easier to swap the whole thing out. Plug and play.
    AZ dont have them.
    Go with Motorcraft is possible. Cap too.
    Rock Auto lists new Motorcraft DA2004 distributor 56.84 no core cheaper than Cardone reman.
    Motorcraft DU30C pickup coil is 24.79 +time removing/install.
    http://www.rockauto.com/en/catalog/f...ule+(icm),7172
    Sounds like your dad's Impala may have had a stuck float and/or sticking or plugged needle and seat from the bad gas. Unfortunately I don't think any amount of hammer blows would have gotten my car to start. From what I recall we gassed up in Munising and hit the road. It ran fine for a few hours after that.
    I think I am just going to replace the coil, TFI module, and distributor with new Motorcraft parts and hope for the best. I can get all three from RockAuto for $150 shipped. I was going to order them last night, but I decided to sleep on it in case I changed my mind in the morning. I think I will also do the TFI relocation to the fenderwell. I see the local LKQ has a couple of 96 and 97 Thunderbirds in stock. Hopefully at least one is a V6 so I can liberate the TFI heat sink from it.
    '97 Thunderbird
    Could have been those. Rubber hammers remind me of the event but unfortunately not the details.
    Another:
    One night coming home from Downriver Cruise, the Mustang started bucking like a bronco.
    Would idle or run fine floored. No go otherwise.
    Roadside carb inspection, under 7-11 lighting, revealed pieces of debris in carb bowl and in p-jet.
    Cleaned it out, car ran normal all the way back home. Saved the debris for inspection once home.
    Later, magnify glass confirmed black carb bowl gasket flakes.
    My theory:
    Fuel slosh made them float in the bowl then block the primary jet when it came online.
    No mid range cruise.
    Secondary jet provided WOT fuel because all the debris was sucked up by the primary jet.
    Fuel for idle was somehow not blocked.
    Also had the dist thing, coil pickup, intermittent stall, hesitation.
    Coil pickup is mounted on dist adv plate. Wires exit dist housing thru strain relief to connector.
    Wires from the coil pickup fatigued and cracked at the strain relief.
    Well I've had the parts sitting in my house long enough waiting for the snow to stop when we just got more today. I was able to make it to the junkyard last weekend (sans snow) to liberate a TFI heat sink. Much to my chagrin when I lifted the hood on the '96 T-Bird there I realized they had switched to DIS that year. You wouldn't believe how hard it is to find a Ford vehicle with a distributor in a junkyard these days. I finally wandered to the van and truck section and found a mid 90's Econoline with a SBF and a remote mounted TFI module and the rattiest looking TFI module heat sink you have ever seen. I cleaned most of the scabby corrosion from the heat sink and got to making my own remote mount for this. Sure I could order a pre-made relocation kit and that would be easier, but I'd rather build it myself.
    I think I found a place on the driver's side fenderwell where I can mount the heat sink and since there are 10,000 holes there already from the factory I am sure I can find at least one to mount the heat sink to so I'll only have to add one more hole to properly mount it. It looks like I will have to lengthen the current TFI harness about a foot to reach its new location. Shouldn't be too bad. I started collecting the parts to create the relocation harness to go from the dist pickup coil to the ignition module. I can only hope it will stay cool enough on the fenderwell. Anything has to be better than right on the distributor where it is about 5 degrees cooler than the surface of the sun though.
    '97 Thunderbird
    St. Louis, MO.
    I think that relocated TFI should be fine. Also still put heat grease on the back of the TFI. Mine has been on the fender for 5 years now and has not overheated once.
    Scotty
    Past Pony's.....
    I hope so. I still have to drill one hole for the TFI heat sink to mount to the inner fender. I do have my old Radio Shack tube of heat sink compound to coat the back of the module with so I should be covered there.
    I constructed the wiring harness to go from the distributor to the TFI this past weekend using this as a guide: https://www.youtube.com/watch?v=U-O0SVtt8zk and I fabbed up a cover plate where the TFI used to mount on the distributor. Also, in case anybody is wondering for future reference, the spade connectors that come off of the TFI and plug into the pickup in the distributor are .188" wide. I found some female connectors that were the correct size (Dorman 85446) https://www.dormanproducts.com/p-165...origin=keyword and they fit well on the TFI module. I could not find the corresponding male connector in a .188" width at the store I was at so I just filed down some .250" width connectors and they appear to be nice and tight in the distributor pickup. They do make a .188" male terminal though if you can find them: https://www.dormanproducts.com/p-207...origin=keyword
    When I went to lengthen the harness that plugs into the TFI module I found that three of the wires were shielded. Not wanting to tempt fate I extended the shielding on those three wires using the same method as above. Hopefully it works fine.
    All that is left to do is to install the new distributor with new pickup (what I think was the root cause of all the issues). Of course my old distributor had the screw on rotor whereas the new distributor uses the press on style so I had to get a new one. I think I will keep the cap and wires as is for now. They look brand new as did the spark plugs that I replaced. I am pretty sure the woman that sold this had a complete tune up done before I bought the car.
    '97 Thunderbird
    Well that wasn't too bad. Pulled the old distributor out and dropped the new one right in. Distributor cap looked brand new so I feel pretty good about reinstalling it on the new distributor. Even though I dropped the distributor in with the crank at 10 BTDC I still managed to get the timing retarded initially. I try. Got it timed and set and it should be good to go. If this stalling issue turns out to be the fuel pump I am going to be pissed. Oh yeah. Better remind myself to put my fuel pressure gauge in the car if it happens again.
    '97 Thunderbird
    St. Louis, MO.
    Sounds like your good to go. I hope as well it's not the fuel pump but every time I've had a pump problem they failed completely.
    Wishing you luck.
    Scotty
    Past Pony's.....
    Well almost a year from the first time it first stalled it did it again today. My wife has been driving the car pretty regularly all summer with no issues (mostly stop and go around town). She went to pick our son up from a class he takes at school. It was pretty warm today, but not exceedingly in my opinion. She was sitting in the parking lot with the car running and the A/C on and it just stalled. Same type of symptoms. Engine would turn over fine, but would not start. I got up there about twenty minutes later, but I didn't have the time or tools to do any troubleshooting. I just went up there after it had been sitting for 4 hours or so with all of my tools in tow ready to do some hardcore diagnostics and it started up fine. Well it was a little flooded, but otherwise fine.
    Just for a recap we have a new Motorcraft distributor with new pickup, new Motorcraft ignition module mounted on later model ignition module heat sink mounted on the inner fender, and a new Motorcraft coil. I also installed some Autolite plugs when I did all of the work not that that would make any difference. I left the plug wires and cap since they looked like they were brand new (unknown brand aftermarket parts installed before I got the car). The only other non-Motorcraft ignition part is the rotor which is a Duralast part.
    I think if have just about covered everything that would create (or prevent) spark aside from something like the ignition switch. Am I missing anything? I might move on to the fuel pump(s) if I can't figure anything else out. That is the hard part with this. Whenever it fails I haven't had my tools to diagnose it and it is relatively difficult to reproduce the problem when I am ready.
    '97 Thunderbird
    Just drove it home and its running like garbage. Stumbling and bogging all over the place. I tried to pull it forward in my driveway (which has a very very slight incline) and I could barely get it to move forward. Looks like I get to dive into Ford EEC-IV CFI diagnostics. Can't tell if it is ignition or fuel yet. Need to pull codes and see if the magic computer has anything to tell me. I was hoping this thing would play nice until its replacement, but I guess not.
    '97 Thunderbird
    Is it running rich or lean?
    In the limited time I spent with it I couldn't tell either way. It didn't smell rich, but I wasn't real concerned about it at the time. First step will be to attempt to pull codes and check fuel pressure. I may also address some other maintenance issues such as an updated cap, rotor, and wires to a known quantity and replacing the fuel filter for good measure.
    I could hear something rattling around in the cat converter, but this did not feel like a plugged exhaust to me.
    '97 Thunderbird
    Okay I had a few minutes tonight to break out the old analog voltmeter. Here are the results:
    KOEO - 31 EGR valve position sensor out of range (low)
    KOER - 31 EGR valve position sensor out of range (low)
    - 33 EGR valve not opening, insufficient flow detected
    - 48 Coil primary circuit failure
    Not sure what to make of the EGR codes, but I don't think they are causing the problems here. Coil primary circuit failure is interesting and I'll need to dig into that a little more.
    I was not able to measure fuel pressure since the brass pintle that presses against the corresponding pintle on the fuel pressure Schrader valve on my fuel pressure gauge apparently broke off. Looks like its time for a new gauge.
    '97 Thunderbird
    Coil circuit? The code sounds familiar
    verify SOLID connectivity on the electronic advance, #1. Solid, all the wires, etc.
    If I had it to do over again on our F250 I would have stripped the wires in a spot and soldered on a direct jumper when I saw it was funky. Ultimately we cut off the connector and put a new spout blade in an old injector plug that was soldered into place.
    The spouts do sometimes go bad internally where they won’t pass enough current which hugely pisses off the ECU. Idles all day, won’t get the hell out of its own way when prodded
    If you replaced the ignition module make sure it was with the correct type.
    Make sure the codes you got are accurate and the code references are accurate for your car. Sometimes generic code lists are plain wrong!
    The ignition module I used is a Motorcraft unit that has been working fine since April or so. I ran KOEO and KOER codes twice to make sure I got everything. I consulted several different code lists and chose what I think fit best with the car. There are a couple of other code 41's that reference a coil pack or something which obviously doesn't apply. There was also something that referenced low air flow which I assumed applied to MAF cars.
    '97 Thunderbird
    http://vb.foureyedpride.com/showthre...lanations-from
    KOEO code 31 = "EVP or PFE circuit out of range"
    KOER code 33 = "EGR valve opening not detected"
    KOER code 48 = "Measured airflow high at base idle (unmetered air bypassing VAF sensor)"
    Sounds like a stuck shut EGR valve and a good enough size vacuum leak to cause stalling...
    http://vb.foureyedpride.com/showthre...s-Testing-from
    Thanks for posting the link to the Probst book sensor tests. I don't have mine anymore.
    The car will idle just fine. I am thinking this might be different from what started this whole thread a year ago. Then it would stall while going down the highway and not restart until it had sat and cooled down for 25 minutes or so. Now it idles fine, but now(at least when I drove it home the other night after it quit on my wife) it bogs and stumbles under any kind of load. I want to check the fuel pressure before I dive in real deep on the rest of the system.
    '97 Thunderbird
    Jul 2009
    Chicago, south subs
    I had some stalling problems with my '86 3.8. It could be a combination of issues. There are a lot of vacuum lines on these cars which are hard plastic. These get brittle developing cracks and breaks. I repaired at least 7 of them on my LTD. I also replaced the distributor. It runs OK now, but I'm not convinced that I found all the vacuum leaks.
    I will definitely dig into the vacuum lines at some point. Too bad it has so many vacuum engine controls. On my Crown Vic if I suspect a vacuum leak I just unplug the vacuum distribution manifold on the firewall and plug the port in the back of the carb to eliminate any non-engine vacuum leaks, but that is just a carb and DS-II setup so it doesn't care. Makes life much easier. I imagine the CFI would get pissed off if I did that.
    '97 Thunderbird
