Just started to put on the t-top seal kit from LMR. I replaced the felt first (came out "okay"), now Im onto just test fitting the main t-top to roof / window seal. My passenger side t-top takes as great amount of force to even latch close, wondering if this was just because how new the rubber is. But, then if latched, both sides have about a half inch gap from the top of the window (when rolled up) to the t-top seal itself.
Passenger side is the worse, but both sides have a LARGE gap. I have yet to install the seal that actually goes on the t-top itself so that might help??
That, and when rolling up the dirver side window it catches the new rubber and stops the motor from rolling it up. So it seems my windows will need adjustments.
Also (last question!) My kit came with a c-channel rubber, I guess this takes unscrewing the c-channel and this goes under it?? ot sure what to make of that seal and if I should use it.
As you can see I have a number of little issues, was hoping to reach out to others to see what experience they had.
Thank all!
