This thing looks really clean.
https://cincinnati.craigslist.org/ct...507741436.html
Looks nice
Typical CL.
The seller spends 3/4 of the ad telling you what he will and will not do instead telling you about the car he has for sale!
Sure gives me a "warm and fuzzy" about the seller.
www.musclecardeals.com
