Results 1 to 7 of 7
    Default Removable bar/receiver trailer hitches
    How many are running something to pull stuff with on their fox? I'm coming to the realization that it may be useful to sometimes put a light and small trailer behind one of my Four Eyed foxes.
    I had a hitch on my 86 at one time and have pictures of ridiculous abuse. I am not looking to repeat that mean-ness but pulling some jet skis or a trailer with track tires or extra luggage definitely isn't out of the question.
    I figure ask for ideas now while the car build is still in the teardown phase.
    I plan on building one for my car sooner or later.
    Can't find any detailed pics of how it should look.
    Jul 2016
    Duncannon PA
    Should be fairly simple. 3/8 or 1/2 inch plate steel for the sides up to the frame rails and 2 inch square tube running between the plates from side to side. The receiver tube and safety chain hook up can be bought commercially.
    The problem I'm thinking about is the thin steel wall frame rails. To do it right a piece of tube should be run thru the frame rail for the side plate bolts. Obviously the thick steel side plates will have to custom cut to come down and back and that will have to be done with a torch or plasma cutter. The bottom of the plates should have a square hole cut in them for the cross tube to pass thru and then welded on both sides of the plate.
    Of course all this steel will add a lot of weight to the very rear of the car.
    Jul 2010
    Houston (Clear Lake), Texas
    I have one for my car somewhere in the storage shed or at the shop. My car spent alot of highway time between Houston and Lubbock. When we graduated from college in the late 80's, my friend (previous owner) bought a hitch so he could rent a trailer and move his things back to Houston. From what I remember it bolts to the backside of the bumper via clamping plates, so no holes or modifications to the car.
    HAD
    HAVE
    Check out Mike's thread, might give you some ideas.
    http://vb.foureyedpride.com/showthre...-Trailer-hitch
    From Mikes post and a little from my dual ehaust post. End plates are welded to and held captive in shear.
    This is not a detachable tonge trailer hitch like Ford USA and Australia use on later Explorers, Sport Utlities and Falcons, but its mounting is what differs between the SN95 and Foxes. I don't like anything that attaches to the FMV approved 5 mph bumper system. The frame rails are what I chose to link it all.
    I do have a motza of pictures from when I did my tow hitch design and trail fit on my 81.
    Sorry, I wont be re-rotating the photos, you have to recheck it in Photobucket because the accelerometer over rides the orintation unless you use edit, then back out, and recheck.....it takes ages, and aint got the time
    Orange/red is passenger side.
    IMG_6124_rotated
    IMG_6127_rotated_driverside_exhaust hanger
    IMG_6140_driverside_hanger
    IMG_6141_passengerside_hanger
    IMG_6164_driverside_exhaust_hanger
    IMG_6165_passenger_side_exhaust_hanger
    IMG_6241_rotated_passenger_side_hanger
    My set up was especially easy, but for one thing.
    The drivers side chassis rail and bumper horn is not symetrical or handed. Its its own shape, offset from parallel by about 5 degress, so that creates about 1/2 " of irregular custom fitting. The frame hasn't been bent, its site permanent reference marks are all good. Its just stamping variances.
    The end plates center spacing from frame rail to frame rail ended up being splayed from the design 40-1/4" to a non perpendicular splay.
    I decided to use both frame brackets cut from 1/4" plate, and add some strips of 1/8" to some M14 bolts (22mm head).
    That resulted in me having to trial fit the parts again and again.
    The arc welder and Igot a good work out
    It took ages and I still have to pull the whole lot out and get the welding and design certified.
    The 2" square tube was bent in a 20 Ton press to get the dip angle right for the tow hitch to come out low enough.
    Many have done it with the earlier type.
    Beware, some store bought SN95 designs and most flange to body Fox designs are inadequate in MHO.
