Results 1 to 5 of 5
    Default Throttle cable brackets?
    I’ve got the 351W set back in after leaking freeze plugs forced me to pull it back out. I installed a dual remote oil filter kit. I had it laying around for ever so I decided I’d use it..
    What are you guys using for throttle cable brackets. The one I have on the engine is too close to the firewall..
    I just got in a new short cable from Summit.
    This picture is with 6 cyl cable..
    Sep 2016
    Anchorage Alaska
    Wow, that cable bracket is close. I ordered one from LOKAR for mine as I need the TV cable for the AOD I'm putting in with the 408. But as I haven't begun my swap yet I have no idea if it will work after looking at your setup.
    The cable shown is the stock 6 cyl cable that was way too long... it is only off 1/2" From the carb to the bracket.
    The new cable is much shorter from carb ball to mount ...I guess I should have taken a picture of the new cable.[h=ATP Accelerator Cables Y-187 from summit]1[/h]
    What carb are you running?
    I have a 351w in my car and I used a stock v8 fox throttle cable.
    I also have a Edelbrock RPM Airgap and 800 cfm Edelbrock carb. I had to make an adjustable adaptor plate to help align everything.
    I'm running a Holley 650 DP
