Hiya guys and gals,
Im new to this so pardon me if i screw up.. I was wondering if i can use some eibachs on my 86gt that i just put 17 inch rims on?
Will it rub? i just think it needs to be a little lower.
Thanks,
Travis
Hiya guys and gals,
Thanks,
Travis
Use the ford racing "B" springs. Better quality and not so low as the eibachs. Just over 200 bucks from jegs.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Personally I prefer using caster/camber plates in front. Those will drop the car around 3/4".
In the past I've also used X2 balljoints during SN95 based 5-lug conversions. This positions the spindle higher relative to the A-arm. It corrects a bumpsteer problem that's common when converting to SN95 parts. It drops the ride height by an additional 3/4".
You could use X2's with other spindle setups, but you'd need adjustable bumpsteer kits to get that part of steering geometry correct then.
On my 1986GT my car is 5 lug converted and sits 1.5" lower using low miles stock 5.0L springs plus caster/camber plates and X2 balljoints. In the rear I'm running 4 cyl LX springs. The car has a very slight rake to it and could use 1/2 a coil cut off of the rear springs to make it level. Rides great. Handles better than any stock 93 Cobra I've been in. Its a joy to drive.
When I went to 17" rims I also converted to 5-lug. i run 245/45/17 tires and they do not rub but it took me a long time to get the front dialed in.
I started out running 83 Ranger 2.0L rotors in front with an SN95 rear diff from a 1995GT in back. The front rubbed terribly and needed a 1/4"-1/2" spacer in front to solve that. When I went to SN95 spindles and 99GT brakes I instead pushed the struts out so they are straight up and maxed out caster by pushing them all the way back towards the windshield. Then I used camber bolts to get the camber where it needed to be.
thanks guys for the help and input. im still running 4 lug and gotta replace the stock shocks and struts so i figured i would do the springs at the same time.
much appreciated.
