    Default Did ford put HO roller cams in any 351's ?
    While I'm looking around at the junkyards...just curious if anyone knows off the top of their head if Ford used the same HO mustang cams in any 5.8 motors (perhaps 90's trucks) etc.
    Thanks in advance
    The 1993-95 F-150 SVT Lightning had the same cam as 1982-84 and 1985 CFI H.O. 5.0L Mustang/Capri.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    The F4TE 351W block is roller cam ready. Doesn't guarantee it has a roller cam in the block, but that block is capable of running any 302 HO or aftermarket roller camshaft.
    Its the truck cam. Its a special type of cam (listed as Version 4, below) Ford made after 1986 to 2001 for OHV V8 SBF's. Cams are listed below to compare. Thanks Walkin'Tall.
    All 94-97 351 windsor engines are equiped with hydraulic roller camshafts.
    Its the Explorer 5.0 cam, basedon a roller cam version of the ancient 351M and 400 Ford 2-bbl cam profile.
    Stock 94-97 F4TE cam specs: 256/266 degree duration (advertised) Lift with 1.7 rockers: .445/.473 , Lobe centerline angle is 116. This cam is just a tad less than a GT/HO cam in lift and duration with 1.6 rockers. Works great with a carb too. The exact same cam used in the 94-2001 5.0's in pickups, vans, Explorer's and Mountaineers.
    It looses 10 hp on a stock 225 hp HO EFi 5.0, and the F3 ZA-CA cam looses about 4 hp on the stock 225 hp 1986-1993 cams.
    For instance, the Australian Ford 5.0's got the 1993 Thunderbird cam spec, and made 221 hp net with it.
    See
    Here is a smattering of the 12 most Revolutionary Roller and Solid cams for post 1986 Port Fuelie 5.0and 5.8's.
    50 thou figures show a lot more on what was going on.
    Stock 85-90 cam is 204°/204° at 50 thou 444 in. 444 ex thou lift ( Version 1 and Version 2 again, Roller cam)
    Overall Roller cam Production figures are effectively four types, revised four times:
    85-88 5.0: E5ZE-6250-AA 266°/266° at lash 444/444 thou lift (Version 1)................................................ ..1st
    89-90 5.0 : E8ZE-6250-CA 276°/266° at lash 444/444 thou lift (Version 2)................................................ 2nd
    91-93 5.0: F1ZE-6250-AA 276°/266° at lash 444/444 thou lift (Version 2)
    93 Cobra 5.0: F3ZE-6250-CA 270°/270° at lash 479/479 thou lift with 1.7 rocker arm ratio (Version 3)...3rd
    94 Cobra 5.0: F1ZE-6250-AA 276°/266° at lash 444/444 thou (Version 2)
    95 Cobra 5.0: F4ZE-6250-DA 276°/266° at lash 444/444 thou lift (Version 2)
    96-01 Explorer 5.0:F4TE-6250-BA 256°/266°at lash 422/448 thou lift (Version 4)....................................4th
    A-cam (Ist flat tappet hyd ) is 204°/214° at 50 thou 448 in. 472 ex...............Deadly Letter A'.....................5th
    A-cam (2ndflat tappet hyd ) is 204°/214° at 50 thou 472 in. 496 ex..............Deadly Letter A''....................6th
    E-cam is 220°/220° at 50 thou 498 in. 498 ex thou lift..................................Deadly Letter E.....................7th
    B-cam is 224°/224° at 50 thou 480 in. 480 ex thou lift..................................Deadly Letter B......................9th
    F-cam is 226°/226° at 50 thou 512 in. 512 ex thou lift..................................Deadly Letter F......................10th
    X-cam is 224°/224° at 50 thou 542 in. 542 ex thou lift..................................Deadly Letter X.....................11th
    Z-cam is 228°/228° at 50 thou 552 in. 552 ex thou lift..................................Deadly Letter Z......................12th
    And Mikes post.
    See note 14...
    1993-1995 "Cobra R" roller cam. Interesting, maybe little known fact, that the F3ZE-CA camshaft was snuck into some '93 Thunderbirds and Cougars...
    Last edited by xctasy; 02-21-2018 at 02:18 AM. Reason: Everything good with what Fox Chassis says. The F4 TE was one of the last new 5.0/5.8 OHV cams
    I can tell you that even though 1994-95 Lightnings had a roller block (F4TE), they still had a flat-tappet camshaft from the 1973 Torino 351W 4V engine, same as what the early H.O. 5.0L engine used.
    The 1993 Lightning had the 'old' non-roller block, except for maybe a few at the end of the model year that got the 'new' roller F4TE block.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
