I recently picked a 84 gt turbo that someone did a "5 lug conversion" with svo parts. It looks like they used the svo lower control arms, spindle/brakes and koni struts up front. Out back, the complete disc 7.5 rear end was swapped in with upper and lower control arms. The guy I bought the car from attempted to replace the front struts with ones for the gt. Needless to say, my drive home was a bit sketchy. So my question is, Do I simply get the correct struts for the svo spindle and keep the non-existent svo parts or do I change back to stamped lower control arms, 87-93 v8 spindle (to keep rotor and svo caliper) and struts because the geometry is jacked without the svo k member? Thanks.
