So I’ve decided that I want a 80/20 drag/street car. I eventually want to run a 351, current engine is a 302, so I’m building my engine around my goals. Since Im basically getting new everything I decided to just go with a solid roller. The guys at comp cam recommended this
http://www.compperformancegroupstore...Code=K35-772-8
Now this kit doesn’t include rockers, but I was looking at the Ultra gold arc series from. They seems fine for my application. Now I know that shaft mounted are probably better for higher rpm applications, and I found these on eBay but I have no idea what to look for. I know shaft rollers are usually $800-1500.
https://rover.ebay.com/rover/0/0/0?m...2F172575516519
They’re a cheaper alternative and I thought it’d be fun to try for $250 compared to the $340 for the comp rockers. What are your guys thoughts on this, I’m looking to have some fun with a build I have. Currently the heads that I’m running on right now are some ported gt40s but I’m getting some AFRs 205s late summer. I’d like to bring in some dyno info to the community about different combos so I’m running my current drag setup with those heads. Would I even be able to run shaft mounted rockers on the gt40s let alone the AFRs? I heard on some AFRs you can’t run shaft but I haven’t confirmed. If I ran the comp rollers, I could always use them on the aftermarket heads.
