Results 1 to 6 of 6
    Default Brake Pedal and Throttle assembly.
    Has anyone had trouble with their work boots fitting between the brake pedal and the rise in the body for the trans?
    I was debating finding a way to shift the assembly to the left an inch. That or is there a narrower brake pedal that we can easily swap to?
    Sent from my SM-G920V using Tapatalk
    You don't state what year, model, and transmission you have.
    The early cars have a flat skinny throttle pedal. The later ones a slightly wider and arched throttle pedal.
    The automatic cars and the SVO have the wide brake pedal. The manual cars have a smaller brake pedal pad to give clearance for the clutch pedal.
    Your post is a bit confusing as to me the transmission tunnel is next to the throttle pedal and not the brake pedal. I do on occasion depending on shoes do have an issue with my foot hitting the throttle pedal a bit when stepping on the brakes due to lack of clearance. I think that is what you mean.
    Other than possibly swapping between throttle pedals, which probably wont gain much, the only other options I can think of is possibly swapping in a different pedal arm that is shaped differently or actually using a torch and carefully bending yours over a bit for more clearance.
    The SN95 pedal arms can be swapped into a Fox and they are definitely shaped different and allow for some different spacing of the foot pedals. If swapping a brake pedal you will have to make sure the actual M/C pushrod pin is at the same height as original. That is nothing more than a little grinding, drilling a new hole and welding the pin again. I have been working on all of that with my 1982 GT and 5.4DOHC Hydorboost swap. Hope that helps some.
    1986 Thunderbird 5.0 AOD. My boot tends to get a little wedged between the brake pedal and the rise in the center of the body where the aod is. They really have the assembly cramped to the right. I think I will swap my brake pedal to one from a manual fox. Thanks for the info!
    Quote Originally Posted by Jackthemind View Post
    See, I have little to no experience with the Thunderbirds, so . . . .
    Being a Fox you can most likely look as the Mustang stuff and see if that helps to gain you needed clearances. Good Luck!
    Jul 2016
    Duncannon PA
    I have the same problem. I wear a size 12 wide boot. It's a tight fit eve with the manual trans setup. Nearly impossible in my svo. The whole setup is made for a size 9 sneaker I think.
    Quote Originally Posted by dagenham View Post
    I feel ya. When I wear my sneakers I'm fine. But these boots are a bitch haha.
