This car is just a few miles away if anyone wants me to go get more pictures of videos for someone who is interested. https://www.missionmotorsarlington.c...tails/40039165
1982 Capri RS 5.0L
I went and saw this car today.. The fog light bare is messed up and the bumper cover is torn a little in that area. The underside of the car looks solid. The paint is 9 and most likely factory. The interior is quit nice but the stearing wheel has been swapped out. The drivers seat will need new foam as its broke down quite a lot. It also has the cruise control on the turn signal stalk. The manual boost controller is under the dash and reminds me of a McLaren turbo mustang unit. As for the motor it starts and runs at 500rpm but it revs smoothly. So hopefully its just need base timing and idle speed reset. The motor does have 86 intake, big throttle body, water cooled turbo, and the a/c pump + lines cut out.
1982 Capri RS 5.0L
