Page 2 of 9 FirstFirst 1234 ... LastLast
Results 26 to 50 of 212
  1. #26
    Jul 2004
    Montebello, CA
    Default wash day
    Before I start all the welding, I moved it outside to give it a pressure wash. tried to remove 30yrs of grime. Also did the 5 lug conversion on the rear with all new brake parts and I found a surprise, so when I removed the rear cover I found it has a yukon carrier and a set of Richmond 4.10 gearsName:  thumbnail (3).jpg
Size:  161.6 KBName:  thumbnail (2).jpg
    Past 4 eyes-
    U.S. NAVY 1980-2009
  2. #27
    May 2005
    Altoona, PA
    Man you CA guys! The lack of rust on that car just astounds us rust belt guys. Around here a 5 year old car wouldn't look that good.
    408/T5/3.73's
  3. #28
    Jul 2004
    Montebello, CA
    Welded on the replacement upper and lower radiator supportsName:  thumbnail (6).jpg
    Past 4 eyes-
    U.S. NAVY 1980-2009
  4. #29
    Mar 2013
    DENVER CO, the 303
    Wow, making some good progress
  5. #30
    Great project!
  6. #31
    FEP Member brianj's Avatar
    Feb 2012
    Raymond, New Hampshire
    Blog Entries
    2
    Already looks 100% better.
  7. #32
    Jan 2004
    Arlington Washington
    Joe your sure making progress! Did you stay sn95 width or fox with on the rear end?
    1982 Capri RS 5.0L
    1985 SVO 2A & leather.
  8. #33
    Jul 2004
    Montebello, CA
    Quote Originally Posted by SchoolBoy View Post
    used the ranger axles
    Past 4 eyes-
    U.S. NAVY 1980-2009
  9. #34
    Jul 2004
    Montebello, CA
    Past 4 eyes-
    U.S. NAVY 1980-2009
  10. #35
    Jul 2004
    Montebello, CA
    I re-hung the fenders after trying to get the dents out im thinking that they are junk and i might have to get new mustang fenders to replace them as i dont want to slop on bondoName:  thumbnail (8).jpg
    Past 4 eyes-
    U.S. NAVY 1980-2009
  11. #36
    Feb 2009
    Snohomish, Wa
    NO!!!!
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
  12. #37
    With a portapower and stud gun you would be amazed at what you can do in terms of dent removal. just heat the metal before making big pulls and be patient.
  13. #38
    Jul 2004
    Montebello, CA
    I know I know..... but there is already bondo in spots
    Past 4 eyes-
    U.S. NAVY 1980-2009
  14. #39
    Jul 2004
    Montebello, CA
    have the new suspension just about done on the front and rear, and also cut off the rear lower and welded on the replacementName:  thumbnail (14).jpg
Size:  111.6 KBName:  thumbnail (15).jpg
    Past 4 eyes-
    U.S. NAVY 1980-2009
  15. #40
    Jul 2004
    Montebello, CA
    I just finished 4 days of splicing and wrapping wires....... what a PITA! just need to check wires with a meter and then install into the dash, but need to pain it first. also ordered 4 new rubber items so she can sit on the ground again Name:  thumbnail (11).jpg
    Past 4 eyes-
    U.S. NAVY 1980-2009
  16. #41
    Jul 2004
    Montebello, CA
    New tires are on, sitting on the groundName:  thumbnail (17).jpg
    Past 4 eyes-
    U.S. NAVY 1980-2009
  17. #42
    Awesome work! Thanks for posting the progress, it's great to see it coming back to life.
  18. #43
    Jul 2004
    Montebello, CA
    Started sanding off that crappy Burgundy paint
    Past 4 eyes-
    U.S. NAVY 1980-2009
  19. #44
  20. #45
    Jul 2004
    Montebello, CA
    I bought a stud gun from Harbor Freight and pulled out all the dents, now working on the front cover fixing all the scrapes, rips and holes. Also installed my new fender extensions on both sides that I got from Johns Cougar.... great fits and well made
Size:  112.8 KBName:  thumbnail (4).jpg
    Past 4 eyes-
    U.S. NAVY 1980-2009
  21. #46
    Feb 2009
    Snohomish, Wa
    Lookin good Joe.
    Dave
    1983 Capri RS Turbo
  22. #47
    Jan 2004
    Keep it going Joe!
    1982 Capri RS 5.0L
  23. #48
    Jul 2004
    Montebello, CA
    I sprayed on to heavy coats of primer and now to start sanding again (used a $20.00 electric sprayer from harbor freight
    Past 4 eyes-
    U.S. NAVY 1980-2009
  24. #49
    Apr 2009
    Denver, Colorado
    Pic's of tools..ya know for us budget minded folks.
    Current rides:
    89 LX 5.0, 5 -spd..the Lemon
    86 RS Capri 5.0 Auto...
    85.5 SVO, Finally Got Boost
  25. #50
    Jul 2004
    Montebello, CA
    Quote Originally Posted by onetrackrider View Post
    Go onto Harbor Freight web site and I think the spray gun is on sale for $15.00
    Past 4 eyes-
    U.S. NAVY 1980-2009
