Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 226 to 250 of 298
  1. #226
    Jul 2007
    Richmond, ME
    Before I came back to the ship, I opened the door to my storage and gazed wistfully at my Zephyr, still sitting patiently. :/
  2. #227
    Apr 2016
    Sprague River, OR
    I'm currently wrapping my Fox. I finished up the trunk tonight and just have the rear quarters, rear flares, taillight panel, sills, and the roof (front half of the car is done + trunk). Should be done in another week or so.
    Attachment 123190
    Join The Conversation
  3. #228
    Attachment 123190
    Guess that makes you a wrapper. one with more talent than several
  4. #229
    Apr 2016
    Sprague River, OR
    Talent is subjective. I'm still a novice at it. I get the basics and am learning on every piece I put on.
  5. #230
    I took the front end off the 82 GT to get ready to sellName:  mustang front 1.jpg
    1986 ACS McLaren Capri
    1971 Mustang
    1968 F100
  6. #231
    Just got my 81 Capri back from paint shop last night. Tonight the new 5.0 and Mercury/Capri badges go on.
    HAD
    14 Mustang GT
    94 Mustang GT
    93 Mustang LX
    HAVE
    81 Capri - 302 with 351 heads, 4 speed top loader
    68 Mustang Coupe - 351W, 5 speed tremec
  7. #232
    Default Car as parts runner for truck
    Car to haul rare like new drivers bucket seat for my 93 Ranger XLT reg cab home from the pic-a-part.
    Truck has hauled car's parts: car returns favor and hauls truck's parts.
    Truck's current 88 Escort GT bucket seat pad is pretty much gone. Storing it.
    Found seat in a 1992 Ranger STX S.Cab. Power lumbar and bolster. Adj thigh support. Manual track. 25.00
    Stripes kind of remind of pc Recaro pattern toned down 100x. Seat cleaned up great.
    Woolite foam and Simple Green. Brush, wet rag, air dry.
    Similar to 80's Mustang GT? Sits higher due to supercab double track stack for tilt and slide.
    Seat track swap/adaption another issue but did it. Reg cab bucket/floorpan has different tracks.
    Photo is the 'yard truck before seat removal. Dirty truck interior, clean seats. Weird. Pass seat had more wear.
    Moved it in a wheelbarrow.
    Name:  seat STX bucket.jpg
  8. #233
    An intermittent cluster light is annoying and not acceptable. Especially the oil pressure gauge area.
    Pulling the cluster is not one of the fun jobs to do.
    Old plastic cluster twist in holes crumble away, twist in light socket loses printed circuit connection.
    Solved:
    Parallel hard wired 3 cluster wedge bulb socket pigtails to existing regular wired dash light circuit.
    Cluster printed circuit overlay is no longer used for cluster light power.
    Rubber grommets fix the damaged, now oversized, cluster bulb holes. Mod 1 done few years ago.
    Been using plastic push in pigtails with the rubber grommets. Work ok, but little loose. Low profile.
    Recently found round 13mm rubber push in type work better. Made to take heat of halogen wedge bulb. Mod 2.
    Now, a solid straight controllable depth fit into rubber grommets. Bright like new, dimmable, inexpensive.
    Just found out slightly larger sockets (15mm vs 13mm) are avail. that may fit without a grommet.
    15mm= DVD center hole.
    Swept bits of white plastic cluster crumbs from under mask with acid brush. Buffed both sides with microfiber cloth.
    Nearby dash VDO voltmeter was not as bright as main cluster. Changed 194 bulb to 2825, blue boot cap. A match.
    Have you thought about the LEDs from SuperbrightLEDs ? I just replaced my cluster illumination bulbs (5) and am pleased.
  9. #234
    Nah no led. Too expensive. I prefer incandescent color temp.
    Blue 194 2cp, 168 3cp, or 5w 2825 with blue caps work fine. Correct no glare soft clear back lighting for night driving.
    Read 194 is about 25 lumens, 2825, 168 50 lumens, LED 50+.
    Removed all blue masks. They crumble from heat. Now the bulbs have more ventilation.
    The problem was the twist in bulb sockets no longer stay in place.
    The plastic holes are 'stripped out'. Sockets no longer contact the printed circuit.
    Hardwired rubber pigtail bulb sockets solved the problem for 6 bucks.
    Solid contact and full power to bulbs glow bright like they used to and are dimmable.
  10. #235
    Jul 2016
    Duncannon PA
    Cleaned up the Saleen for the meet n greet this morning for the start of mustang week
    Current Mustangs
    1966 6 cylinder coupe
    1984 SVO 9W
    1985 Saleen #132
  11. #236
    Sep 2008
    Greenwood, IN
    Flushed out original, 33yr old brake fluid...more like black tar...from my '85 GT this past weekend Did the '82 a couple years ago. Guess I'll do the '93 Feature this winter as well.
    Jason Smith
    MCA #65481
    '82 Capri RS Resto-Mod
    '05 S-281 Mineral Grey
  12. #237
    Jul 2016
    Duncannon PA
    I should do that to a couple of my cars too.
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
  13. #238
    FEP Power Member 81coupe's Avatar
    Aug 2008
    Mount Washington, ky
    Been Running the hell out of her all Summer long. Runs Great and still pulls hard in the upper RPM with the E-303 Cam. Still have not rebuilt the C4 Trams though. Trying to find time to do so.
  14. #239
    Apr 2016
    Sprague River, OR
    I finished the wrap on my '80 widebody project on Friday afternoon last week, then wiped it down for a few pictures. I had a deadline to meet for a wrap contest on Saturday, so I shot some video also. These are my 3 favorite pictures I took on Friday evening at sunset. I started to put the interior back in last night, and should get a lot of it done this week. There is a car show this weekend I'll take it to to debut the wrap in my local area.
    Attachment 123945
    Attachment 123946
    Attachment 123947
  15. #240
    Jul 2016
    Duncannon PA
    Finished up a UPR adjustable clutch cable install in the Saleen tonight. Put it in at Mustang Week but didnt take the big plastic piece off the cable at the firewall.
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
  16. #241
    Drove it 50 mile round trip across town to an estate sale.
    Picked up like new items: vintage tabletop rod hockey game, air hockey, and Sears 10/2a auto battery charger in box made in USA.
    6 or so for gas, 30 for items. A nice weather day and good pick'ens.
    Cool to get long looks, nods, thumb ups at a light from other drivers or road construction workers and is not a show car.
  17. #242
    Got the white painted on the ACS. Next, cut and buff, then do my black.
    1971 Mustang
    1968 F100
  18. #243
    Jul 2004
    Montebello, CA
    Went out to get some quotes on painting the Capri I was committed on selling it but might have a better chance if its painted and re-assembled
    Past 4 eyes-
    U.S. NAVY 1980-2009
  19. #244
    Drove it to get spare factory radio from pic-a part i spotted last week. I use 90's Escort radios.
    Very hard rain on way home later after dark. Avoided puddles and freeway.
    Running light red LED on/off/flicker. Lights were ok. No pattern. Random.
    Checked in parking lot and reflections off store front glass.
    Fogs, lights, defog, wipers, defrost, radio on. Charge 13v+ ok. Belts never slipped.
    Strange.
  20. #245
    Default buck day 1978
    Car was bucked 40 years ago today at DAP.
    Imagine it was painted by this time.
    Assembled on Oct 4.
    Was on the truck for delivery 735am Oct 5 '78.
    Thanks to Marti report, will 'celebrate' by driving it.
    Maybe retrace the 16 mile delivery route from DAP to where the dealer was in 1978.
    Prob will hear Boston- 'Don't Look Back' on the radio.
    Overplayed then in 10/78 and now in 2018.
    1978 zodiac animal was the Horse.
    Prepped a small part of the 40 year old floor pan for future repair.
    Polished rear tail lens.
  21. #246
    Jul 2016
    Duncannon PA
    Going to get my SVO and wifes '91 5.0 from AACA musuem tomorrow. Cant wait. It was cool to have a car in a museum but I'm over that now. I want my car back. I missed driving it all summer.
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
  22. #247
    Dec 2011
    stanton,alabama
Size:  101.8 KBName:  1014182100.jpg
Size:  117.7 KBquarter panel swapping
  23. #248
    Quote Originally Posted by tonysilver82 View Post
    Nice Work!
  24. #249
    Dec 2011
    stanton,alabama
    Nice Work!
    Thanks man and You were a big decision changer in this
  25. #250
    Glad I could help.
