Results 1 to 3 of 3
    Feb 2009
    Jackson, NJ 08527
    Default CFI LX motor roller cam?
    Was this motor roller cam in 85?
    Roller cam/lifters NO. Roller Block YES, supposedly only after the model year started.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Feb 2009
    Jackson, NJ 08527
    OK, thanks.............
