Results 1 to 6 of 6
    Default Cobra Door Tag Decoded
    Could someone let me know what my car was equipped with originally? It's been heavily modified since 1980 although I was curious what some of the options it might've had.
    Do you have a buck tag for this car? How many miles on the odometer? Can you provide a list of all options this car has/had?
    Options list is here: http://foxchassis.com/fep/registry/c...ions/1980.html
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Besides what is shown on the door tag, here is a short list of other options that your car could have come with...
    Backlite Louvers
    Cobra Hood Graphics
    Console
    Electric Rear Window Defroster
    Engine Block Immersion Heater
    Fingertip Speed Control
    Four-Way Manual Driver's Seat
    Front Floor Mats
    Front License Plate Bracket
    Interval Windshield Wipers
    Leather Wrapped Sport Steering Wheel
    Light Group
    Lower Bodyside Protection
    Mud and Stone Deflectors
    Power Front Disc Brakes
    Power Lock Group
    Power Variable Ratio Steering
    Premium Sound System
    Protection Group
    Rear Window Wiper/Washer
    Tilt Steering Wheel
    Tinted Glass (Complete)
    Tinted Glass, Windshield only
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Both the buck tag and original gauge cluster were removed before I purchased the car as it's been turned into more of a street/strip race car. I wish I knew more about the car than I do but I was told it was originally a turbo car (of course a buck tag would prove that 100%) however I'm confident it was between color as well as having the turbocharged dash with the cobra emblem and it doesn't appear to have been switched out. By the door tag was this an automatic or 4 speed car? I was able to decode the exterior/interior color codes and the engine code but I've not been able to find the rest of what's listed.
    VIN
    0 = 1980 model year
    F = Dearborn Assembly
    03 = Mustang 3-dr hatchback
    A = non-turbocharged/turbocharged 2.3L engine
    134544 = 34,544th 1980 Ford scheduled for production at Dearborn Assembly
    Door Tag
    Date - 10/79 = October 1979 scheduled build
    GVWR - 3800 lb/1723 kg = gross vehicle weight rating
    Front GAWR - 1985 lb/900 kg = front gross axle weight rating
    Rear GAWR - 1835 lb/832 kg = rear gross axle weight rating
    F0087 = 87 lbs front accessory reserve load
    R0068 = 68 lbs rear accessory reserve load
    Exterior Paint Colors - 9D 1C = Polar White upper (9D), Black lower (1C) (tu-tone paint)
    DSO - 53 = Kansas City district sales office
    Body - 61R = Mustang 3-dr hatchback
    Int Trim - AD = vinyl seating with high-back front buckets (A), Red interior trim color (D)
    A/C - A = factory air conditioner
    R - 5 = AM/FM stereo radio with 8-track tape player
    S - 0 = no sunroof
    Ax - F = 3.45:1 axle ratio, non-locking differential
    Tr - 6 = Borg Warner 4-speed "RAD" manual transmission
    VV = front springs
    FF = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Thanks FoxChassis!
    I've been trying to decode as much as possible. Wish the buck tag didn't get removed.
