Hi I have a 84 thunderbird with a 302 and a c5 the previous owner took the motor out so I’m having to do a lot of searching to figure out where some stuff goes. Never messed with an auto trans before until now. I want to make sure the bracket that holds the shift lever is in the correct spot. If it is great if not where does it go correctly. Also on my column shifter it goes into the low gear notch on the column and the shift handle Maxes out. But if I go under the hood I have to pull the linkage on the trans to get it to actually click into 1st gear. There’s a nut and bolt on the linkage that connects the trans to the steering column rod to chose the gear. I’m assumig that just needs adjustment to make the gears line up with there correct marks. Sorry if this is a little confusing. It’s been a long one.
