Results 1 to 14 of 14
Thread: hatch problem!
    FEP Power Member BLK BRD 88's Avatar
    Dec 2010
    Next to the Chimney
    Default hatch problem!
    Hi all,
    I am having a hard time getting the hatch to close as it should on our 84 SVO. I assume that the hatch latch is the same as many different Foxbody Mustangs, so hoping someone can jump in here to give me some suggestion on adjustment or whatever is needed.
    We have to shut the hatch with a lot of force (like slam), then it rattles/thumps as we hit bumps on the road.
    Any helpful suggestions are appreciated.
    Ron
    I never seem to get the nut that holds the steering wheel fixed
    Apr 2008
    Waikoloa , Hawaii
    Is there a bushing on the body latch?
    https://www.youtube.com/watch?v=dOIXAgvfhVs
    1986 CHP SSP Coupe
    Barboursville, WV
    I have the same problem with my 88gt, and it's completely my fault. It was missing completely, when I got the car. I had an extra door striker lying around. They look similar, but I'm thinking they may be slightly different. You have to slam it a few times to get it to latch and it rattles pretty bad. I rarely ever open it or drive the car, so it stays on the backburner along with a few other minor repairs.
    The hatch striker bushing is generally the biggest issue with hatch rattles and lack of latching properly. A good quality hatch seal and then properly adjusted hatch bumpers are the other two issues that can eliminate hatch issues.
    Is the hatch original to the car or was it replaced?
    If it's been off, hinge shims are another topic worth discussing.
    They often rub between the quarter and the hatch too. This is because the curve on the hatches is actually not quite right compared to the body creating contact in the middle.
    Grand Rapids, MI
    Interesting. The hatch on my LTD wagon rattles like crazy and generally doesn't hold very tight at all. I've been around Fords for quite some time now. I don't know why checking to see if the striker bushing had disintegrated was not on my list of things to do.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    Been there, done that. You gotta know to understand....
    I win the Russell Cosby Ushanka hat award for NCAA....No Class At All.
    Here is the garage tech garden hose replacement. This is a stop gap untill I can afford proper striker catches early next year.
    The six point star tool has to be a Torks T50, and a Predator or whatever electric drill probably won't be enough.
    A work mate suggested an impact driver, but I didn't wanna ruin a borrowed tool from a workmates Bahco S910 Socket and Spanner Set 92 Piece 1/4 & 1/2in Drive set
    So I used:-
    my special 18" shifter,
    his Torx T50, and
    some hot water,
    replacement hose pipe, and .....
    mamas steak knife!.
    Here's the result. NCAA, No Class At All , but a temporary fix.
    [url]
    See
    Quote Originally Posted by sowaxeman View Post
    You can do MUCH better than that by buying the actual bushings at your local auto store, split them down the middle with a good pair of side cuts and slip them over the striker bolts, then super-glue the seam back together. I did this on my cars and the fix has lasted one year thus far.
    Look for a write up on this in Fox Mustang Magazine soon
    Dec 2010
    Next to the Chimney
    "You can do MUCH better than that by buying the actual bushings at your local auto store, split them down the middle with a good pair of side cuts and slip them over the striker bolts, then super-glue the seam back together. I did this on my cars and the fix has lasted one year thus far."
    Why did the new bushings have to be split in order to get them on?
    Doesn't the striker post come apart so the new bushings can be slipped over the end as shown in the xctasy pics above?
    Ron
    Apr 2008
    Waikoloa , Hawaii
    ^ some do, some don't - on the doors particularly
    1986 CHP SSP Coupe
    Feb 2009
    Snohomish, Wa
    Strikers consist of the bolt, the bushing and a washer. The bushing fits between the bolt head and the washer. The washer was put in place prior to the threads of the bolt being cut which increases the diameter of the bolt so the washer won't come off without damaging the threads.
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    Feb 2009
    Snohomish, Wa
    oops
    Dave
    1983 Capri RS Turbo
    Dec 2010
    Next to the Chimney
    Ok I get it, thanks to all of you who responded to my question. It sounds like more than our SVO has had this problem.
    Ron
    FEP Member Dadsccat's Avatar
    Oct 2014
    Niagara Falls , Ontario, Canada
    After reading this thread, I ordered a new striker from NPD because I have the same problem. Very hard to close and rattles. When I looked at my old striker it had no bushing at all. Installed the new striker and closes perfect now. Thanks all.
    Shawn
    Currently in the stable:
    83 Capri RS Crimson Cat
    90 7 UP Mustang
    87 Mustang GT
    83 Porsche 928S
    69 Thunderbird Landau
    65 Cadillac Calais 4DR Hardtop
    02 Thunderbird
    May 2003
    Roseburg Oregon
    The hinge bushings also go bad , causing rattles .
