Results 1 to 16 of 16
    Default Pulsating lights. Entire car issue
    I cleaned all my grounds. I added a ground from my battery to my frame. Same size wire as ground to engine block. Replaced voltage regulator. Been debating on going 1 wire 130 amp alt to eliminate some wiring/ possible issue. Battery measures 900 caa rates at 730. I been dealing with this over a year. I just don't drive at night. Any help is greatly appreciated.
    Sent from my SM-G920V using Tapatalk
    Quote Originally Posted by Stangsgt83 View Post
    I cleaned all my grounds. I added a ground from my battery to my frame. Same size wire as ground to engine block. Replaced voltage regulator. Been debating on going 1 wire 130 amp alt to eliminate some wiring/ possible issue. Battery measures 900 caa rates at 730. I been dealing with this over a year. I just don't drive at night. Any help is greatly appreciated. I have an 83 gt. 5.0 5spd
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    "Pulsating". Is it a consistent pattern or random? Also when you say entire car when the lights are on; interior, dash, parks and headlights all the same time?
    My first thought was that it may be a loose wire at a connector and that you may want to wiggle and check some of those. Maybe I am thinking more of a "flicker" than a pulse.
    Darran
    Have you replaced the headlight switch?
    Interior lights and exterior lights pulsate at the same rate. If i give it gas it increases the rate of pulses. I'll take video tonight so it's more visible and post it.
    Multi function switch replaced but not the pull out on off switch.
    Sounds to me like a bad headlight switch if you have done everything else. I would definitely give that a try. You don't state what year and model you are working on, so we can only guess.
    The Fox headlight switch is know to deteriorate over time and it seems to be even worse on GT/RS models with Fog lights in my experience. Ford runs a lot of load thru the switch, so its only a matter of time before things start overheating.
    Oct 2014
    Calgary, Alberta, Canada
    The pulsing indicates a voltage sine wave. Only way that is happening is from the alternator; probably has some bad diodes in it. It'll likely die outright soon and your lights will just be constantly dim, problem solved.
    The plug on the pull out on off headlight switch might be loose, vibrating with vehicle vibration...
    In case you're not versed in this, and this is an '83 we are talking about... headlight switch removal:
    - disconnect battery negative cable from battery
    - reach up behind the dash in there and you'll feel a button on the top of the headlight switch case, press that down
    - pull the knob and stem all the way out
    - unscrew (counter clockwise) the chrome/other outer trim collar where the knob/stem was
    - take the switch back and down
    - see what shape the plug (and the wires/connections to it) is in and whether it's loose, and/or replace the switch if it's "relaying" out sporadically shutting lights off and on...
    Otherwise, may be a charging (alternator, regulator, wires/connections continuity, etc.) issue, which will be affecting more than just the lights. What does a volt/multi meter say when connected to the battery terminals while idling?...
    I tested my system with a snap on starting and charging system tester. Pic are the results.
    I have ordered a motorcraft switch to swap out this week. I am a tech just starting out. I do have a snap on charging system tester. I took a pic of the results. I'm trying to post a video of the lights in action. http://cloud.tapatalk.com/s/5a6e5bf9...128_181821.mp4
    Here is the videohttp://cloud.tapatalk.com/s/5a6e5db0...128_181821.mp4
    Your voltage is out of range -- too high. Its probably the voltage regulator.
    79-85 those are on the fender.
    86+ they are integrated into the back of the alternator
    My son's 86GT did the exact same thing then it smoked a perfectly good battery so I replaced the alternator and battery and cables.
    That is my educated guess.
    That's what I was debating on. I been looking to see what 15 volts all the time would do to my car. I think I'm going to buy a 1 wire altenator with it integral to the case. My old wires are cracking now I been digging in to it. I wraped all the spots i found in electrical tape.
    Yeah, I agree with the alt thing.
    A good setup should be 13.5-14.5 under full load at idle. A completely stock 2g in my car while turning on every power sapping thing I could at once barely dropped it to 12.9 if I remember right.
    I like my max voltage to be about 14.2v. If its higher then that, it will boil off the battery over time in my experience.
    ^ this ^
    what he said. Smoked battery, or exploded. Depends upon your luck. Mine have literally melted the case before. Took a good long while with baking soda to get all the acid neutralized.
