Results 1 to 4 of 4
    Default How is the center console mounted to car
    I am installing a 85-86 mustang center console in my 81 fairmont. How are then held down to the car. Are there brackets of some sort?
    FEP Power Member 81coupe's Avatar
    Aug 2008
    Mount Washington, ky
    Can't remember the front mounting, but do remember that the back off the console was mounted by 2 screws inside the arm rest at the bottom. Them screws went into a bracket that was welded to the trans tunnel under the back of the console. Shaped like a U-Bracket. Would not be hard to FAB up in a pinch.
    There is a front bracket also that the area under the ash tray mounts to.
    Oct 2014
    Calgary, Alberta, Canada
    Bracket under the back is screwed down as is the one on the front. There are also two screws directly through the plastic into the tunnel under the brake handle cover.
