Results 1 to 3 of 3
    Default Instrument cluster
    Does anyone make a printed circuit board for the SVO. Mine has many issues and it would make sense to just replace it at this point.
    Are there any breaks in the traces? It looks like there was some heat from the old bulb, LED's get rid of that heat. What isn't working?
    I thought I had seen some at NPD, but just looking now I couldn't find them. So either I am mistaken or I am imaging stuff now.
    You can make repairs to your circuit board if you have a break in one of the circuit lines. Often that is all that is wrong. I have even seen some solder wires from one side to the other to fix a broken circuit. Maybe not the best option, but it does work if you can't find a replacement.
    If you need/want a replacement then I would recommend posting a WTB in the Classifieds. Most likely someone here on FEP has what you need. Heck, I might have one myself, but would have to look at my clusters to verify. Good Luck!
