I've been shopping for a brake caliper and pad and rotor upgrade for my 85 Saleen clone build. I'm reading product descriptions and reviews and this time I just had to give a shout out to my FEP friends based upon what I'm seeing!
example -
https://lmr.com/item/SVE-2320SVO/198...CABEgJ6ePD_BwE
There are many other similarly constructed upgrade kits.
the problem is they don't tell you that you also need the SVO 1 1/8" bore master cyl and an adjustable brake proportioning valve and matching rear SVO brakes to safely run those 73mm calipers!
check out the comments about the product. No kidding more pedal movement is needed! Get used to it?! That's insane.
Anyway..... I'm looking at going with SVO spindles to correct Ackerman and staying 4 lug on my 85. I'm shopping for calipers and pads that will work well with a 4 lug 87 tbird/93 cobra rear 4 lug brake setup.... adapter plates and the rear brake setup
Great brakes that are 4 lug is the end goal.
Anyway - I just had to give a shout out and state my observations. If anyone knows of parts I should consider let me know.
