Results 1 to 4 of 4
    Default Alternator upgrade
    Looking to upgrade my alternator on my 82 gt.what should i get? Running electric fan.
    You have a few choices. Running an electric fan may push you up to the next level. Many fans draw a fair amount of power. You can upgrade your 1G to higher output, 100 Amps. 3G is the way to go for steady high output. There are lots of posts calling out the small case model and the needed wiring upgrades.
    Quote Originally Posted by 82g View Post
    Are you looking to keep the cost down?
    If not, I got the top of the line PA Performance 100% brand-new alternator.
    If you order directly from PA Performance, you can also get the alternator powder coated for $40 extra. For me, it helps to keep the "salting" down from the aluminum case.
    From their catalog, for your '82, here's what you'd need:
    http://www.paperformance.com/200a-3g-alternator-1619ho/
    200A 3G Alternator (1619HO)
    $309.00
    Product Description
    This is a very popular replacement where highly increased capacity is needed. This kit is more popular for highly (electrically) modified cars. Being slightly larger diameter than early (1965-1985) Ford alternators some minor bracket clearance / modification may be needed. You can see this in the “tech info” page.
    http://www.paperformance.com/1g-3g-conversion-462802c/
    1G-3G Conversion (462802C)
    5 Stars 3 product reviews
    $34.95
    Product Description
    This kit is made specifically for the installation of a Ford 3G alternator on any vehicle where the stock alternator was EXTERNALLY regulated. We incorporate a new replacement external regulator box (as shown) to capture the proper circuit and retain the stock wiring harness along with our own 3-wire (3G Series) regulator plug. This kit allows the customer to retain the OEM warning lights and shunt type ammeter **
    http://www.paperformance.com/premium-short-9905/
    Premium Short (9905)
    $49.00
    Product Description
    30" Premium Kit offers outstanding performance, cosmetics and flexibility. Premium Wire is mad of electrolytic copper. The OEM wire from the alternator to the vehicle was not designed to carry the added load of higher amp alternators.
    Note: I do not know how long the wire has to be for an '82.
    For my '86 I got the following:
    http://www.paperformance.com/premium-long-9902/
    Premium Long (9902)
    5 Stars 1 product review
    $69.00
    Product Description
    110" Premium Wire Kit offers outstanding performance, cosmetics and flexibility made of electrolytic copper to reduce whine or noise in a stereo. The OEM wire from the alternator to the vehicle was not designed to carry the added load of higher amp alternators.
    More info:
    http://www.paperformance.com/content/462802C.pdf
    http://www.paperformance.com/content/2015CATALOG.pdf
    Good Luck!
    IF you want to go the Salvage Yard route:
    here is a little info that may help you find the one you are looking for:
    The 3g is Ford’s most popular alternator for
    91-2003. Some vehicles are equipped with the 3g even later than
    that. You know you have a 3g if you can see the entire gray or white voltage
    regulator on the back of the alternator. The regulator is what you had to
    unplug the wires from. There is no visible cooling fan on the 3g. It comes
    in 95 and 130 amp versions but takes the same rebuild kit. Notice the 2
    holes between the 2 ribs in pic 1. This is a 130 amp. If there were 4 holes, it
    would be the 95 amp
