Finally trying to get the SVO running. Everything is pretty much new. I’m not getting spark when cranking. It gives me a small jolt when I stop cranking. I’ve swapped in a known good ignition switch, distributor and coil. Still no go. This is an LA3 swap. I double checked my pin swap. What does the computer need to see from which sensors. Does the computer send a signal to the pip or tfi to fire off the coil? I have 12v at the coil w the key on. I also have 2 wires at the tfi w 12v but one powers up while cranking. I also see a resistor wire on the - side of the coil. Last thing...looking at the wiring diagram it says the wiring to the distributor goes thru a breaker less ignition module...is that the same as the TFI? Because the plugs they call out on the diagram don’t look to match anything in my wiring harness.
