Results 1 to 25 of 38
    Default 84 thunderbird vin decoding
    Just got ahold of an 84 thunderbird and wondered about the rear gears and tranny code on it. Here’s the vin and a pics of the door sticker
Size:  91.2 KBName:  51220A76-FD08-4598-85E4-2E41DF99B300.jpg
    AX code "8" = 2.73:1 conventional
    TR code "C" = C5 auto.
    F0251 = 251 lbs front accessory reserve load
    R0090 = 90 lbs rear accessory reserve load
    DSO - 17 = Washington district sales office
    Ax - 8 = 2.73:1 axle ratio, non-locking differential
    Tr - C = C5 automatic transmission
    CC = front springs
    JJ = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Can you post the buck tag for this car?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Where’s it located at? I looked on the rad support but couldn’t find it
    80 Capri built 5.0 single turbo manual trans
    86 mustang coupe built 351w single turbo manual trans
    84 t bird built 5.0 c5 auto
    It would be on the radiator, same place as a mustang.
    If ya want I can try to post mine off my 86.
    I will look for it tomorrow. I didn’t see it today though. I can’t imagine it would be gone. The car had never been apart and is original for the most part. I assume the build sheets in it most likely.
    Each assembly plant may put the tag in a different place.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Do you have any idea where it might be at?
    Check the TOP of the radiator core support. (Not the front face.)
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    I’ll give it a look later on. I assume it’s there somewhere car was a 2 owner. Guys grand mother and than him. Interior has never been removed either, so I’m hoping I can locate a build sheet.
    Look for build sheet under the lower half of the front seats, between the seat foam and the 'springs'.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Alright I will when I can get to it. Snows winning this battle today
    Finally got outside to look. Was able to locate the build sheet under the passenger front seat. Still haven’t been able to locate the buck tag though.
    I am trying to confirm the year on it. The build sheet says may of 1983 but the door tag says sept 1983 but a vin search came up 1984. I do not have the title currently the previous owner is waiting for a replacment to get mailed to him and he claims to not know the year for sure either. If anyone could verify it I’d appreciate it. Thanks
    The VIN decoder tells you what model year it is. The 10th character is the model year. E = 1984
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Okay thanks. The door tag and what not through me off. I figured it was built in 83 but sold as an 84 or something. Still can’t find no buck tag
    Models years don't follow calendar years. Model years end/start around late August or early September. So a 1984 model year vehicle can be built in the last four months of the 1983 calendar year.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Were you able to get the build sheet out of the seat bottom? Can you post a pic of it?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Yeah I got it all out and it’s in suprisingly great condition. I’ll post up a pic soon for you to see
    This is all I can decode on the build sheet. I don't have a whole lot of Cougar or Thunderbird sheets.
    Build Sheet
    Line A
    Rotations Number - 0432 = trim & chassis rotations #0432
    Line - S = Thunderbird model line
    VIN - P46EA100970 = [VIN decoded above]
    Body Type - 63D = Thunderbird 2-dr sedan
    Body, Tops, Roof - [blank] = no sunroof
    Ext, Paint, Body - 1C = Black exterior paint color
    Ext, Paint, Accent - [blank] = no accent paint
    Ext, Tutone - [blank] = no tu-tone paint
    Int, Deviation - [blank] = no interior trim deviation
    Type of Order - 2 = Stock order
    Region & District - 17 = Washington district sales office
    Special Order - [blank] = not a special order
    Line B
    Emission Control - [blank] = no special emissions system
    Engine - 3 = 3.8L V6 engine
    Trans - C = C-5 automatic transmission
    Air Cond - M = manual air conditioner
    Engine, Tag Number - EK506AA = 1984 49-state calibration (E), Thermator emissions with or without A/C (K), 3.8L V6 engine (506), release level AA
    Transmission, Part Number - E4SP BA = automatic transmission (S) originally engineered for 1984 (E4) Thunderbird (S), release level BA
    Seats, Type - 2 = low-back bucket seating
    Belts, Color - D = Red seat belts
    Line C
    Imm Block Heater - [blank] = no immersion engine block heater
    Line D
    Electrical, Wipers - [blank] = no interval windshield wipers
    Electrical, Defroster - [blank] = no electric rear window defroster
    Electrical, Audio, Radio - A = AM radio
    Electrical, Lights, Light Group - [blank] = no light group
    Power Aids, Deklid Release - [blank] = no remote decklid release
    Power Aids, Locks - [blank] = no power door locks
    Power Aids, Windows - [blank] = no power side windows
    Glass, Tint - T = tinted glass
    Mouldings, Rocker - [blank] = no rocker panel moulding
    Air Dam - [blank] = air dam without foglamps
    Road Abrasion - [blank] = no road abrasion coating
    Carpet/Mats - [blank] = no floor mats
    Console - [blank] = no console
    Mirror, Vanity - [blank] = no passenger side vanity mirror
    Line E
    Battery - DB = unknown battery
    Driveline, Speed-O, E05 - [blank] = no metric speedometer
    Suspension, Springs, Front, Left - SAB = C front left spring code
    Suspension, Springs, Front, Right - SAB = C front right spring code
    Suspension, Springs, Rear, Left - JAD = J rear left spring code
    Suspension, Springs, Rear, Right - JAD = J rear right spring code
    Pkgs, Hndlng - [blank] = no handling suspension package
    Line F
    Tires, Size - 1957514 = P195/70R14 tires
    Tires, Color - W = white sidewalls
    Tires, Spare - M = mini spare
    Tires, Quantity - 4 = four full size tires
    F28 - [blank] = no fingertip speed control
    Front End, Steering Wheel, Type of Col - [blank] = no tilt steering wheel
    Frt License Plate Bracket - X = front license plate bracket
    Line G
    VIN - 1FAB3 = [VIN decoded above]
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Excellent info as always. Thanks for the help
    Feb 2006
    Allentown, PA
    My findings show that Atlanta build Thunderbird's did not get a buck tag like the Lorain built cars.
    To date I have never seen a buck tag on an Atlanta Thunderbird.
    Since we know all about your car now, how about some pictures.
Size:  142.7 KBName:  7B372D43-7187-4F38-ADF7-5F555D9702CF.jpg
