Results 1 to 4 of 4
    Default Low profile electric fan
    Looking for the best low profile 16" electric fan .no more than 2-1/2 thick do to clearence issue.thanks
    Jan 2004
    Arlington Washington
    Try looking through the spal website but if the entire fan with motor needs to be less than 2.5" thats gonna be a tall order.
    1982 Capri RS 5.0L
    Can you fill us in on what's going on with your setup? Maybe there's another option. For instance, I have a single e-fan with no clearance issues. If I did have issues, the deepest part of the fan (motor) could be offset enough to not interfere with the water pump snout. It's an aftermarket Chevy hhr fan.
    Sep 2016
    Anchorage Alaska
    Or if clearance is tight in the center, you could do smaller dual fans.
