Results 1 to 18 of 18
    Default need advice in Tires.. new setup WIP
    My 86 GT convertible is going to be lowered soon... I just got the coilovers and wheels. This is mostly done for the looks. I don't drive my car very often, just for some weekends a year to shows etc. I know the choice of parts might not be the first thing to think about in the USA, but it's quite difficult to get nice parts for reasonable prices from the USA here in the Netherlands... So I made my own choices with parts that can be found in europe.
    It already has MM rear control arms.
    The rims are 8x17 and 9x17, both are ET20. So backspace on the front will be 5.29" and on rear 5.79" In the back, there comes a spacer (20mm = 0,78") too, in the front there might be a spacer of 5mm needed.
    My main question is what size tires I should go with. I think I have to roll my fenders either way...
    I am thinking about 255 in the back with 235 in the front, but what heights would be best? Any thoughts?
    Thanks for any help/advice!
    Greets from the Netherlands, Jeroen.
    And has onyone got the same size on its fox who is able to share a picture?
    Oct 2014
    Calgary, Alberta, Canada
    I'm running the same size wheels on mine with 235/45-17 front and 255/40-17 rears. I don't have a good picture showing the tires and wheels on yet though.
    Is that on your red-silver project with the black wheels? that's looking pretty awesome... But i'm not planning on rebuilding the complete front fenders...
    Oct 2014
    That's the car. The front fender mods were to accommodate the suspension mods which moved the front wheels 1.5" forward.
    I am running 255/40/17 front and rear with 17x9 Cobra R's on my 79 PC.
    245/45/17's fit well on my 17x8 wheels.
    I agree with trey - 255/40/17 fit well on 17x9.
    thanks a lot!
    Oct 2014
    You may find that the wider sizes some are running up front will not clear your coil overs. That was one of the big issues I had choosing wheels and tires and why I went for the sizes I did. I could have run wider up front but would have had to keep spacers in and widen or flare the fenders.
    Thanks, I will have to check it out... What et size are you running on your red hatch?
    So I went for the 255/40/17 on the rear, and got 235/45/17 on the front!
    I lowered it, replaced the front bushings for polyurethan versions, replaced the alternator for a 3G version, and fitted the wheels! Still got some work to do... Need spacers on the front, since the tire is rubbing to the coilover, need to roll the fenders (at least on the back) and rewire the alternator...
    What do you think of my new look to my '86 'vert?
    Feb 2009
    Snohomish, Wa
    Shiney
    Dave
    1983 Capri RS Turbo
    1981 Black Magic 400 c6
    93 F-250 351 5sp 4x4
    FEP Power Member BLK BRD 88's Avatar
    Dec 2010
    Next to the Chimney
    Jeroen,
    Your 86 looks great with those wheels and tires!
    Ron (an old Dutchman in Az.)
    I never seem to get the nut that holds the steering wheel fixed
    Nice!!
    - CA car, 5.0 w/5 speed
    Looking good!
    Thanks! Nice to see another dutchman here!
    FEP Super Member escogt's Avatar
    Jan 2006
    Long Island, N.Y.
    Cool wheel setup. I like it!!!
    '85GT Bright Atlantic Blue
    '92LX Bimini Blue-sold
    '93 COBRA Teal Metallic-sold
    '86SVO Oxford White-sold
    '86GT 'Vert True Blue-sold
    '81'GT' Medium Red-sold
