Hey Guys, I've built a new 302 for my 85 LTD LX that I'm running a carburetor with and I'm using the 94-95 stock steel valve covers. My question is how would I run the PCV system with these valve covers? I'm using an Edelbrock Performer RPM Air Gap manifold, there is only 1 vacuum nipple on the oil fill tube, the other V/C has no holes in it. Can I just run a PCV valve between the nipple on the V/C oil fill to the carb? Or does it need a breather? I don't plan on using the dual snorkel again, if it clears the hood I'm definitely in, but with the Air Gap I don't think it will. So I'm not sure what kind of air cleaner I'm going to use. Any advice would be great!
