Results 1 to 9 of 9
    FEP Supporter vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default MSD Wire Boots Close to Headers... Too Hot?
    I have a set of the MSD wires, and the plug ends are straight. I was considering getting a set with 90 or 45 degree elbows, but I think these straight boots should work fine. I am pretty sure the boots are silicon, so they should be fine this close to the headers, right?
    You should be able to bend those a little. I always use 45’s instead of the straights
    There are also sleeves to protect the boots from various vendors like these:
    https://www.amazon.com/010542-Titani.../dp/B006MVPIAI
    85 GT - owned since 87
    May 2017
    Beaverton, Oregon
    Yea, I have seen the sleeves... I was mostly just hoping to get by with these, since they are brand new, and I figured that the silicon would be safe, but probably just need to bite the bullet and get the 45 degree boots. These came with the car, so I didn't have to spend another $100. Especially for the initial break-in of the engine, my guess is that the headers will get pretty toasty, and they could melt these boots.
    FEP Member brianj's Avatar
    Feb 2012
    Raymond, New Hampshire
    Blog Entries
    2
    If you're buying new ones, go 90. Much cleaner and easier.
    +1 For using Spark Plug Boot Protector Sleeves. :-)
    Quote Originally Posted by stangplus2birds View Post
    +1 for using spark plug boot protector sleeves. :-)
    ...........x2
    84 Cougar, 88 HO with 700DP, Edelbrock RPM intake, 1.7 RRs, shorty's and SS exh, T-5, KC clutch, Hurst pro billet, line loc, 8.8, 4.10s, suspension mods....blah, blah,blah.
    Jan 2003
    lansing, mi
    The MSD boots don't hold up to the heat very well. The sleeves will definitely help, but you need to get those boots away from the headers for sure.
    Cale
    May 2017
    Beaverton, Oregon
    I went ahead and routed wires so that they are at least 1/4" away from the headers, and I went ahead and got the sleeves as well.
