Results 1 to 4 of 4
Thread: Interior swap
    Default Interior swap
    Hey guys I have an 85 TTops I'm looking to restore. I have 0 interior plastics and have stumbled across someone sell a full set of plastics from an 88 TTops car. ARE there any issues I can run into if I purchase them?
    I assume you are referring to all the interior parts and pieces that are plastic and not just the T-top specific items.
    Yes, you can swap the 87-93 interior into your Fox. There are differences, some more difficult than others, but still essentially a bolt in affair.
    The dash mounts to the firewall in a slightly different fashion, but workable. The instrument cluster and most of the dash wiring is completely different than the Four Eye so you will need to address that if doing the swap.
    The center console is a bolt in with only needed to swap the brake assembly and drill a couple of holes.
    Door panels will work just fine, although the switches and wiring are different. Also some of the door panel clips will be in different locations. As will some of the arm rest hardware.
    The quarter panel interior trim will fit, but you will need to trim @ 3/4" off the area that meets up with the quarter windows as the Four Eye glass bolts in from the inside and the aero windows bolt in from the outside. The rest of the hatch trim will bolt in although you may have to drill new holes for many of the pieces.
    I think that covers the majority of items. I am sure there is something I have forgotten. Most of the misc trim plastics are interchangeable with little or no issues. Good Luck!
    Thank you that helps alot
    Sure thing!
    I understand your situation, so parts availability may make your decision for you, but . . . .
    If it were me, I would stay with the Four Eyed dash as it will make your life much easier unless you can get the misc parts needed to do the swap from a parts donor or at a really good price.
    The door panels, rear quarter panels, etc. are personal preference. I like the PW/PL switch placement better on the Aero panels than the Four Eyes for a DD type setup, but the panel itself not as much. The aero rear quarter panels have a better speaker placement if that is important to you, but otherwise, not much of a difference. Do keep in mind that the rear hatch carpet is different too for the Aero cars due to the different shape of the interior trim, so factor that in if you already have carpet. Good Luck!
