Page 3 of 3 FirstFirst 123
Results 51 to 67 of 67
  1. #51
    FEP Member Mgino757's Avatar
    Jan 2011
    Virginia Beach, VA
    That's what I'll be doing because I love my factory valve covers.
  2. #52
    Jan 2011
    Virginia Beach, VA
    Well, this project never came to fruition. Still have the stock engine with tired heads. I did just pick up a set of 4 bar GT40P heads that I'll recondition and build on. I paid all of a whopping $50! I plan to have them milled .010-.020", port the exhaust ports, throw a good set of springs on them (Alex's Parts). I will be changing the camshaft too. Power goal is 265-300 hp. A buddy of mine wants me to run a B303 cam, I'm not 100% sold on that idea. I don't like how his runs with it, his car has ported and shaved GT40's and B cam. It runs good, but it doesn't really come alive until just shy 3,000 rpm. I want a cam that'll provide a little more low end grunt since I have 3.55's and being a heavier convertible. I'm willing to spend up to $350 on a camshaft. I was eyeballing either the TFS stage 1, Comp 281HR, or Comp 270HR.
    I'm open to feedback.
  3. #53
    Here is what you want and need.
    http://www.flowtechinduction.com/fti...ord-austemper/
    A custom spec'ed camshaft will make you more power and better drive-ability than any off the shelf camshaft. Worth every penny and will absolutely blow your buddy's Alphabet camshaft away.
  4. #54
    Feb 2009
    Jackson, NJ 08527
    The twisted wedge will give you the most PTV clearance options, and can get you to those levels with a mild cam and decent intake.
    Yup. I have 170's on my 86, true flat tops with stock cam and 1.7 rollers.
    So an 85 should be fine.
  5. #55
    Jan 2011
    Virginia Beach, VA
    Another set of heads I have my eye on is the newer Ford X2 Street Cruiser heads, just in case I decide to ditch the GT40P's. Any insight on that bit of info?
  6. #56
    Jan 2011
    Virginia Beach, VA
    I think for headers, I'm going to take the plunge and step up to long tubes. I'f I'm going to spend $400+ on a set of shorties, I may as well go full tilt and get more for my money. I can run them while I get ready for the head swap.
  7. #57
    I bought the BBK "least offensive" shorties for my GT40P heads. Hope to have them on in a month. If you can wait that long...haha...I can tell you how they work.
  8. #58
    Jan 2011
    Virginia Beach, VA
    Quote Originally Posted by Str8sixfan View Post
    No Problem there. I am definitely interested in seeing how those fit for you. That could literally save me a few hundred. It's a shame GT40p headers are so expensive now. $420 for a set of shorties is flippin ridiculous. They used to be about the same cost as regular shorties. MAC knows they have the monopoly on them now. Of course now, any used sets are seemingly impossible to find.
    Would these work? The collector seems to have the correct primary tube arrangement for GT40P fitment.
    https://www.summitracing.com/parts/s...1004/overview/
  9. #59
    Those headers look like the same headers you can get for sixty bucks all day on Ebay, I have a set on my 86 coupe with 88 drivetrain. They worked and fit fine, but are a little thin in the steel tube. I don't see how they'd work on Ps as the tubes swell outward from the port flange, intruding into where the spark plug sits on p heads.
  10. #60
    Jan 2011
    Virginia Beach, VA
    Would it be worth the cost and effort for me to switch to long tubes on an otherwise mild combination? Despite the exhaust obstacles, minor at best, I still like the appeal to running these heads. After all, I can say they're "stock Ford heads" lol. Plus it's what I've got.
  11. #61
    Jan 2011
    Virginia Beach, VA
    How much difference would long tubes make over a set of shorties on a mild setup like I have in mind?
  12. #62
    Quote Originally Posted by Mgino757 View Post
    With long tubes you might lose some bottom end torque depending on your combination. Overall power will most likely be the same with a possible small increase at the top end. Nothing wrong with long tubes compared to shorties, the issue for you is more $$ and any of the downsides to long tubes. Long tubes often have less ground clearance than the shorty setup. Depending on the flange on the long tubes you can have exhaust leak issues. What if any modifications/changes might be required to stay emissions legal is another. Long tubes can also adversely affect hot start issues because of additional heat near the starter motor. Starter motor removal/install can be more of a pain due to clearance issues. Same for install and removal of headers and the engine can be more difficult with long tubes compared to shorties. If you already have a good H/X pipe and you go to long tubes you will either have to modify yours or buy a new H/X pipe make sure to factor that into your overall costs too. Good luck!
  13. #63
    Jan 2011
    Virginia Beach, VA
    Sounds like I'm sticking with shorties then. This car does mostly cruising and the occasional trip to the 1/4 mile track and back.
  14. #64
    Jan 2011
    Virginia Beach, VA
    Well, header problem is solved. Scored a set of Ford Racing shorties. Room for days for the spark plugs.
    Now I just have to decide on a cam. It has also been suggested that I run an E303 cam. A friend of mine said he ran the E cam on his tbird before switching to a custom camshaft, supposedly he saw no difference at all between the two. The primary purpose of this car is to be a cruiser that occasionally goes to the track. I want to shift by 6000-6200 rpm. I also want good torque in the 2000-3000 range. I'm thinking a cam with maybe 218-225 @.050 duration, up to .535" lift, and 110-112 lobe separation angle.
  15. #65
    Jan 2011
    Virginia Beach, VA
    Started porting the GT40P's today. I put almost two hours into one of the exhaust ports today. I was being very careful trying not to get carried away.
  16. #66
    Nice.GT40p's are good quality with those mods.If you can do it yourself well, they make excellent power on a carb car with a good intake. The best thing is they match the old Cleveland 2Vs unmodified; cfm is not compromised at high lifts.
  17. #67
    Jan 2011
    Virginia Beach, VA
    One of my exhaust ports, finished. There are 3 others like it, still have 1 to go. I have about 6 hours total in this head so far.
    I've made the short side radius as smooth and gradual as I could. The walls have been smoothed, but I tried my best not to take much material away so port velocity doesn't suffer. I only cleaned the floor, but didn't take any material away. I did most of my work on the port roof and the area around the valve guides. I also smoothed any sharp ridges in the bowl area. I also smoothed the area behind the guide to have it match the roof radius as best as I could, being careful not to hit water.
