Hello all,
Just replaced my tail and turn signal lights with Super bright led brand LEDs and now I now have the two lights on the message center reading that the brake and turn signal lights are out. Is there a fix for this?
Tom.
Hello all,
Tom.
the only workaround for that is to install resistors in line to trick the message center into not thinking the bulbs are out
These are the ones I installed in my 84 vert.
https://www.superbrightleds.com/more...hoC4IMQAvD_BwE
Be advised they get HOT so find a safe place to cut them into the wiring. I put 4 of them in my trunk for the brake and tail lights. I used digital flashers like these or the dashboard blinker goes really fast. https://www.summitracing.com/parts/p...xoCFLwQAvD_BwE
