    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Installing Headlight Relay Harness
    I just bought a dual relay headlight harness last night, and hoping to get it installed this weekend. From what I can see, everything runs through the factory drivers side hi/low beam plug, so I am considering pulling the passenger side headlight wires and sockets out of the harness that crosses from the drivers side to the passenger side. The main purpose would be to thin out the harness, and run the new ceramic plug H4 harnesses across in place of the factory wires. It should be safe to pull these wires, right?
    The timing seems optimal since I have the front end off of the car and I am in the middle of routing the engine harness around the engine bay.
    Just curious if there was any reason not to pull the factory wires out of the harness?
    One final question... I bought a harness for about $40, and there are some as cheap as $15 or $20, all with ceramic headlight plugs. The pic below is of the Painless Wiring version of the same harness, except that it has standard plastic headlight plugs. Can anyone explain why, other than maybe higher quality relays, Painless wants $200 for their harness?
    May 2017
    Beaverton, Oregon
    Has anyone else removed the right side of their headlight harness, or do most folks just leave them in place?
    FEP Member brianj's Avatar
    Feb 2012
    Raymond, New Hampshire
    Blog Entries
    2
    I stripped all of the original harness, and just used one high and one low beam wire as trigger wires for 2 relays, installed where the battery used to be. Worked well, eliminated a bunch of old, brittle unnecessary wires.
    Quote Originally Posted by vdubn View Post
    What's the difference between a POS GM that rusts in 5 years and has head gaskets blow like crazy (GM has a LONG history of designing sheet metal and heads to last xxx-long). Or, the difference between "beef" and T-bone?
    Fwiw:
    Imho, those of us that work on, and have worked on 15+ year old POS GM cars, learn quickly about the quailty of parts, and how it effects long term reliability/problems.
    With the above, you have the many possibilities for low-cost cr*p:
    Internal Wire - purity, number of strands, material - will it rust/oxidize?
    Wire covering - is it rated for heat, temperature, long term use - will it deteriorate?
    Terminals: Materials and purity - will they rust/oxidize?
    Connectors: Materials and purity - will the plastic deteriorate and fall apart from the heat/cold.
    Loom: Materials and purity - For example, GM is infamous for cr*p looms that deteriorate and fall apart from the heat and/or age.
    It all depends on how long someone is planning on keeping a car, the use of the car, etc.
    My car is over 30 years old. ALL of my GM cars were in worse shape after 10 years than my 30 year old Stang. And, I plan on keeping my '86 for another 30+ years - with using it as my good weather summer daily driver. So, for my Stang, I'm not doing repairs, upgrading, or buying based on cost. I'm doing it based on what I think will last the longest.
    Also, I lost the desire to screw around replacing stuff a long time ago (e.g. buy cheaper stuff, replace more often).
    Good Luck!
    Apr 2008
    Waikoloa , Hawaii
    Your information center will show you have a headlight out, if you have one.
    1986 CHP SSP Coupe
