My Dad and I installed a Holley 4010 on his 83 Capri back in the late 80's and that was the first carburetor I ever worked on. I now have a few of these Holley 4010 carburetors and I want to get the one on my 85 working better. I have always thought that the low speed jets were too rich, and I have to set the idle screws at 1/4 turn out to get it lean enough at idle. Since I have accumulated some spare 4010 parts, i am going to try my hand at significantly altering this carb for the better.
I have started by going through the carb, cleaning all the passages, replacing gaskets, installing new needle and seat valves, and installing a new power valve. I also installed new throttle shafts since the originals didn't have provisions for the throttle shaft seals and I wanted to seal it up a little better. While doing the basic rebuild, I measured and photographed all the jets and air bleeds to establish the baseline which I have recorded below. Once I get the carb back on the car, I'll drive it and datalog the AFR as well as report the driving characteristics.
Hopefully some of the carb gurus on this site will be able to help me out.
Primaries
.038 low speed jet
.044 first low speed air bleed
.055+ low speed emulsified jet
.044 second low speed air bleed
# 66 main jet
.022-5 main well air bleed
.044 anti siphon air bleed
.041 power valve channel restrictor
6.5" power valve
.034 accel pump nozzle
218 accel pump cam
Secondaries
.038 low speed jet
#76 secondary jet
.022-5 main well jet
.044 anti siphon jet
234 accel pump cam
