Results 1 to 13 of 13
    FEP Supporter vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Dash Panels - Instrument Cluster Panel - Woodgrain, 1985, 1986 Checkered
    I have a bunch of instrument cluster bezels for sale from a stash of parts I got with my car.
    First is a wood grain set that is both sides, instrument cluster and above the glovebox, with good fasteners on the back of the glovebox panel, and all the extensions on the instrument side are in tact. I believe these are Ghia, or early 1979 to 1982 Mustang
    $80 for the set
    Next is what I believe is a 1986 Instrument Cluster bezel, as it has the square grid pattern. $40 for this one, its in great shape with all vents, and the rubber trim around the column in good shape. I think someone removed the green film behind the turn signals, but I need to check.
    This next one is what I believe to be from an 85 GT, but could be from other years, as I don't know what exactly fits what. I know they are interchangeable and can be used in other cars. It has one missing tab on the left, with some deformation from what looks like a hot headlight switch. Still in good shape overall. $25 + shipping
    Interested in the '86 bezel. PM sent.
    Sep 2005
    Mtn Home Air Force Base, Idaho
    the grid came on my 84 lx 5.0 coupe.
    66 7 Liter Galaxie 4 sale
    66 T-bird 4 sale
    67 GT500 clone
    68 Cougar 302 c4
    72 Pinto 2.3 turbo soon
    79 2.3 Turbo Pace Car
    83 5.0 5spd GLX vert
    83 GT 5 spd blk/blk
    84 GT Turbo vert
    84 v6 to 5.0 SROD hatch
    84 5.0 5 spd LX cpe
    86 Capri bubble butt, painted!
    86 5.0 5spd LX hatch
    89 5.0 aod LX hatch GRM $2007 entry 12.57 @ 111
    89 2.3 auto cpe w/v8 susp/brks/strng 4 sale
    90 5.0 aod the "cruck" a little bent
    86/90 GT 5spd, 90 met a phone poll
    92 5.0 5 spd LX coupe
    97 Taurus SHO, i weld cams
    www.j4jps.com
    May 2017
    Beaverton, Oregon
    All still available
    May 2017
    Beaverton, Oregon
    Up to the top
    May 2017
    Beaverton, Oregon
    Still available
    Quote Originally Posted by stormy69 View Post
    And my 85 former 4cyl coupe
    Sent from my iPad using Tapatalk
    May 2017
    Beaverton, Oregon
    These are still for sale.
    Quote Originally Posted by vdubn View Post
    PM'd you on the woodgrain bezel set
    Current
    1980 Mustang Coupe 302-AOD
    1986 Mark VII
    Past
    1986 Thunderbird Elan 5.0
    1980 Mustang Coupe 2.3-Auto
    May 2017
    Beaverton, Oregon
    Replied
    Think this would fit right in an 86 GT? My original one has the cut outs with the fake allen head bolts lol. I like the look of this better. Anyone know if they're interchangeable?
    May 2017
    Beaverton, Oregon
    Yes it should fit your car, no problem
    May 2017
    Beaverton, Oregon
    Wood grain dash is gone.... still have the other two
