    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Wheel Center Caps - FORD, Cougar, Thunderbird, etc.
    I have some spare center caps from 10 hole wheels for sale.
    First is a set of 3 caps that have the Ford logo on them - $30 shipped for the set
    Next is a set of Cougar Center caps, same size as the Ford ones - $30 for the set of four
    I think I have a set of Thunderbird caps as well, and I will try to get some pics of those.
    Mar 2013
    DENVER CO, the 303
    Ill take the cougar ones, email me payment info stangman116@yahoo.com
    May 2017
    Beaverton, Oregon
    Yea, let me look when I get home, and make sure I have the T-bird ones still, and I can send them all together. Stangman, I'll email you after I get home as well.
    May 2017
    Beaverton, Oregon
    Ok, unfortunately I can't find the T-bird center caps... sorry.
    Stangman, I sent you an email with the payment info
