Hi, Dose someone here know for sure if the 15" turbine wheel from a mustang gt (do not know the year)will fit on over the calipers on a turbo coupe rear disc brake swap that has stock fox body axles/ trac width? thank you
14" wheels might fit. Turbo coupe rears use the same calipers and brake disc as the Taurus and base fox. These came with 14" rims from the factory.
15's work fine.
I have a set of 14" and no good. I have new set of 17" for when it done so need something to roll it around on. found set of 15"s
I've seen 10 holes and turbines on turbo coupes, so they have to fit.
