Results 1 to 25 of 50
    Default My Indy build with T top conversion
    Well the time has come to start working on it. I've had it for over 20 years and I've done nothing to it. Only 36k miles but had a blown turbo on it when I got it. Going to rebuild the turbo and clean and regasket the engine. Then it goes outside for a bath.
    '79 Indy pace car T-top
    '81 Cobra
    '81 Cobra T-top
    '82 Mustang GT T-top
    '87 Corvette
    '10 Mustang GT Convertible
    '17 F250
    '17 Landrover Discovery Sport
    Well it's about TIME!
    Said the man with mulitple Foxes that haven't been touched affectionately in years!
    Good luck with the overhaul and bath!
    Jan 2006
    Western MA
    Greg - haven't seen you around here in forever, welcome back!
    Better late than never on your PC. And does that ever need a bath
    BTW - what ever happened to your 82 GT T-Top Mustang?
    1986 SVO Mustang - 1C
    Dammit I need some mesh wheels. Good luck!
    Still have the 82 GT. It's taken apart down to the shell and I've been picking away at the body work.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Jan 2006
    Western MA
    Quote Originally Posted by gregpro50 View Post
    Good deal - your 82 was one of those that inspired me to do the resto on my 82 GT T-top car aka the rotter.
    Engine out. Still has the original plugs and wires.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Still has aluminum drums.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    All clean now. In process of rebuilding the turbo. The front bearing went and was pumping oil into the intake.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Cleaned the cobra while I was at it.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Jan 2006
    Western MA
    Looks much better - I like the rims on both cars...
    Engine going back together. Turbo rebuilt.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Lookin good. Pics of these times are important.
    32k, 38y OE plugs wow. Souvenirs.
    Fun part- reinstall of the turbo. And reconnecting exh. pipes.
    10x easier to do with engine out.
    The best part is hopefully yet to come. The car's 2nd life.
    Driven mine longer (2000-present) that 1st life (1980-1987).
    Am enjoying it even more now.
    Uh, both having bought these cars 20+ years ago reminds me:
    -Retaining them intact, inactive, then reactivating to driveable status. Not always easy to do.
    -Having made at least one smart decision, when younger, that also turned out to be wise.
    All new gaskets, seals, water pump, timing belt and tensioner.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Apr 2012
    Springfield MO
    Did you have to use a special tool on the timing belt tensioner?
    MCA #110307
    83 GT T Top
    83 GT Convt
    84 GT Convt SOLD 08/18
    Quote Originally Posted by 83GTJIM View Post
    No. I've always just used a pry bar to give it a little more tension than the spring can give and tightened the set bolt. If you leave it set to the spring tension it will skip when the belt breaks in.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Good news. Engine done and ready to go back in the car.
    Bad news. Sunroof pan is completely rotted out so you lucky people get to see me do a T-top conversion on this car.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Pic of engine.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Engine back in. Runs like a champ. Turbo spools now and no more smoke.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Jan 2006
    Western MA
    What - no video of it running???
    Congrats on the engine refresh project completion!
    Working on the exhaust right now. Then video.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    You are so lucky, you car misses all the extra Cali noodles
    verses
    verses
    The factory tailpipe tips are still in good shape. I got a Walker replacement tailpipe for a 87-93 4cyl and I'm going to cut it down and weld the tip on it.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
    Jan 2006
    Western MA
    That twin tip looks mint. I did something similar for my 82 GT, bought an aftermarket twin chrome tip and welded it on to a stock LX 5.0 tail pipe....
    I was debating on getting the splitter the SVOs used and running duals but the original tips are in such good shape I might as well use them.
    '81 Cobra
    '81 Cobra T-top
    '87 Corvette
    '17 F250
