    Jul 2016
    Duncannon PA
    Default Reman Holley 4180
    Has anyone here bought one of the remanufactured Holley 4180 4 barrel carbs offered by the parts stores?
    If so how well do they work and do I need to keep anything from the old carb? With the fire and all I now have to replace a lot of vacuum lines and Im thinking about trying to go back to completely stock.
    The price is literaly within a few dollars of replacing with an edelbrock so I would like some opinions.
    In general, I have a very poor opinion of parts store reman carbs, not the least of which, because carburetors
    should -never- be sandblasted. But beyond that, I've seen too much mix-and-match, and marginal cores in
    reman carbs, and many of them never run right no matter what you do to them.
    I personally would not use a parts store reman carb, without completely going through it first. And given that,
    there's little reason for me to ever use one.
    I would much rather start with a tired original core that hasn't been molested by the rebuilder mills.
    Cheers,
    Jeff Cook
    Jul 2016
    Duncannon PA
    Well I have that option too since I have an original carb that I could go thru and freshen up
    If you've got an unmolested original carb, I would never trade that in on a reman. The Holley kit for a 4180C
    is p/n 3-1346. About $50 at Summit.
    The original 4180C is a more accurate carb than the Edelbrock, and the annular primary boosters give the carb
    more booster signal and better atomization, particularly at part-throttle. Typically, the annular boosters are good
    for about a 4-6 number decrease in main jet sizing for an equivalent fuel mixture. Don't make the mistake of
    thinking this is just an emissions carb. The things that made it good for emissions also make it an excellent
    performer on a 5.0 HO.
    Cheers,
    Jeff Cook
    I agree with what Jeff has told you above (there's ALOT of lack of attention to detail and ham-fisted butchery that goes on out there... nobody is going to exercise the care and concern for your carburetor than you), and would work with (inspect, clean, rebuild) whatever you have, be that an aftermarket or a factory carburetor. Sorry about the fire you had, but all that requires is a fuel leak source (gasket, needle & seat, whatnot) and a source for ignition... and there isn't any brand or type of carburetor (or fuel injection and high pressures, for that matter), that hasn't got the potential to leak.
