I like my Vision X 9007 bulb 4x6 housings. They're different, but don't scream different. They're cleaner looking, work better, and are DOT approved.
My vote is for stock appearing but better quality. I am not a fan of the crystal clear lights or blue lights. I do like the Hella H2 style bulbs which you can get in brighter voltages. You may need to rewire with relays so as not to overtax the stock wiring or switch. There are plenty of diagrams out there that outline the process. Sweet looking car by the way, I like the underhood treatment by the hood latch and the super smooth engine bay. Post more pics once its all together.
1984 LX 5.0 Vert *SOLD*
I did 4x6 glass housings, h4 led for low beams, h1 for high beams.
Bright, white but doesn’t blind other drivers. Looks stock too.
I like the original look, with all H4 to double low beam. I can't find clear lens lamps approved here in Finland.
Honestly once properly adjusted, I've never had anything but good things to say about visibility with stock style replacements in a halogen bulb.
The only down side is they draw more power than stock so after a lot of years and miles of use the wiring deteriorates to the point that relays are required as dimmer switches and headlamp switches start burning up left and right. Mine was fine until 350K miles and I swapped to halogens at 100K. They reached a point where with near continuous high beam use the lights would flicker off and on after an hour of driving then. It got to the point that low beams wouldn't stay on reliably by 360K. I converted to starter relays for my lights and haven't had another problem since.
I went with the SYLVANIA H4656 SilverStar Sealed Beam. Much better then stock but still have a factory look.
Robert
My RS in Action
