https://chicago.craigslist.org/nch/c...375948439.html
thanks for your interest- i have up for sale a 1986 mercury capri- I have owned the car for the past 5 years and has been inside the whole time- the car has a lot done to it , Runs drives and dose great burnouts- asking 8500 Or Best Offer- Clean tittle ready to roll
if you have any questions please contact me at this number- 1847-SixONEthree-59three3 ask for Charlie- thanks
1986 mercury Capri RS 5.0
Engine-
Gt40 short block worked over to a 331 ci
Gt40 cylinder heads, mild port and polished
High output upper and lower intake, ported and polished
Comp cams 544 intake 555 exhaust 266 durertion at .50 roller
matched set of lifers springs and retainers
double roller timming chain
mass air conversion-high flow F.M.S air meter
M R motorsports computer
70 mm polished throttle body
70 mm EGR spacer- polished
Bosch injectors- ithink they are 35 lbs but not 100% on that
new timing cover
edelbrook water pump
SVO fan
Ford motorspots aluminum rad
k&N air filter
Trans/Driveline
New world class t-5 trans
pro 5.0 shifter
10.5 king cobra aluminum clutch
adjustabled cable heavy duty
Ford motorsports alumimum drive shaft
lakewood drive shaft loop
8.8 rear end with positrac- and 3.55 gears
Suspension-
lakewood 70/30 front struts
lakewood 50/50 rear shocks
eibach drag launch kit springs (lower)
afco low friction ball joints
competition enginering subframe connetors( welded in )
Wheels and tires
16x7 pony wheels
nitto 555r 245/50/16 drag radial rear
goodyear eagle 225/55/16 front
comes with an extra set of centerline wheels
Misc.
all brakes are new, pads,rotors shoes and hardware
new weatherstripping for doors and hatch
new heater core
kenwood radio
new fog lights
new headlights
new power window motors
stainless steel door sill plates
Cons- paint chips in hood, very very small about of rust right by gas tank lid
