Results 1 to 6 of 6
    FEP Senior Member ddx77's Avatar
    Jul 2011
    Fort Lauderdale, FL
    Default 1986 Mercury Capri RS-5peed - $8500
    https://chicago.craigslist.org/nch/c...375948439.html
    thanks for your interest- i have up for sale a 1986 mercury capri- I have owned the car for the past 5 years and has been inside the whole time- the car has a lot done to it , Runs drives and dose great burnouts- asking 8500 Or Best Offer- Clean tittle ready to roll
    if you have any questions please contact me at this number- 1847-SixONEthree-59three3 ask for Charlie- thanks
    1986 mercury Capri RS 5.0
    Engine-
    Gt40 short block worked over to a 331 ci
    Gt40 cylinder heads, mild port and polished
    High output upper and lower intake, ported and polished
    Comp cams 544 intake 555 exhaust 266 durertion at .50 roller
    matched set of lifers springs and retainers
    double roller timming chain
    mass air conversion-high flow F.M.S air meter
    M R motorsports computer
    70 mm polished throttle body
    70 mm EGR spacer- polished
    Bosch injectors- ithink they are 35 lbs but not 100% on that
    new timing cover
    edelbrook water pump
    SVO fan
    Ford motorspots aluminum rad
    k&N air filter
    Trans/Driveline
    New world class t-5 trans
    pro 5.0 shifter
    10.5 king cobra aluminum clutch
    adjustabled cable heavy duty
    Ford motorsports alumimum drive shaft
    lakewood drive shaft loop
    8.8 rear end with positrac- and 3.55 gears
    Suspension-
    lakewood 70/30 front struts
    lakewood 50/50 rear shocks
    eibach drag launch kit springs (lower)
    afco low friction ball joints
    competition enginering subframe connetors( welded in )
    Wheels and tires
    16x7 pony wheels
    nitto 555r 245/50/16 drag radial rear
    goodyear eagle 225/55/16 front
    comes with an extra set of centerline wheels
    Misc.
    all brakes are new, pads,rotors shoes and hardware
    new weatherstripping for doors and hatch
    new heater core
    kenwood radio
    new fog lights
    new headlights
    new power window motors
    stainless steel door sill plates
    Cons- paint chips in hood, very very small about of rust right by gas tank lid
    Apr 2009
    Denver, Colorado
    Ummm
    Current rides:
    89 LX 5.0, 5 -spd..the Lemon
    86 RS Capri 5.0 Auto...
    85.5 SVO, Finally Got Boost
    Mar 2017
    middleboro massachusetts
    Quote Originally Posted by onetrackrider View Post
    Ummm
    i said the same thing....wow..that really sets it apart from the rest!
    Sold this one 10yrs ago. Was my wife's daily summer driver. I did not...repeat....DID NOT put the hideous shifter stick/T handle on it, lol. It had a pro 5.0 base with a hurst stick/boot/white knob with the correct console cover. Hopefully they took that stuff off. It was a Ford GT40 302 long block that was installed right before I got it and it ran well. It went 13.26 @ 107 mph with those nittos on the pony wheels.
    Jan 2003
    lansing, mi
    Nice car no doubt, a hard sell this time of year at that price but I hope he gets it. Dunno how anyone can use a t-handle on a manual, that and the foam need to go. Again though, no engine shots.... but there's 5 different pics of the front end, one double posted in case you missed it.
    Cale
    Sweet shifter setup............lol. looks great. Home Depot rocks!!!!
