Results 1 to 4 of 4
    Sep 2014
    Freeport NY
    Default interior door handle wont open door
    on the driver side of my 84 convertible the inside door handle no longer unlatches the door with normal pull.
    If I snap the handle hard and fast I can get the door to open but its getting worse.
    Inside the door the handle connects to a long rod that connects to the door latch. When pulling the handle to open the door the rod pulls and rotates which I assume is what unlatches the door. I thought that the rod may be stretched from years of use so I tried putting a small bend in it to shorten the travel when the handle is pulled but it didn't fix the issue.
    Is the rod the issue or the latch in door that catches the bar?
    I don't want to put my door panel back on until I solve this, and a minor widow guide adjustment.
    Power locks or no power locks?
    A bad power lock actuator adds quite a bit of resistance to the interior handle release. If no power locks, then it's probably in the latch mechanism. You can try closing the latch with the door open to rule out binding due to the striker engagement.
    Take off the door panel. Clean everything off that you can get to. It will be dirty and really greasy. Everything you can't get to, I like to regrease with white lithium in a spray can. White lithium will collect dust (as will any other grease), but is much smoother then most creases and holds up food under preasure and heat (not that either really matters inside the door.).
    Also make sure the door has no play in the hinges. Its really easy tho check, open the door and try to lift it up. If it moves at all, door hinges have play. You can get a dorman kit from an auto parts store pretty cheaply. You basically drill out the hinge and get a bass bushing onset to take up the slack, then it should be good to go.
    Another thing to check on a convertible especially is body flex. I think we've all jacked up the car and tried to open the door before and not been able to.
