Results 1 to 4 of 4
    Sep 2016
    Anchorage Alaska
    Cool The 408 is alive!
    Got the 408 fired up that I'm pulling out to put in the Fairmont this winter. It's been sitting outside with no carb on it for 10 years. Wanted to hear it run before pulling it out and selling the current 5.0. Make sure you listen to the video on some good speakers!
    https://youtu.be/8HEv0tIL8lc
    Sounds great can't wait to see it in the Fairmont!
    Matt
    Sep 2016
    Anchorage Alaska
    Another teaser vid of the 408 going in my Fairmont this winter. https://youtu.be/JiprfxE6Zm4
