Results 1 to 2 of 2
    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Headlight Trim Rings, Headlight Buckets with Trim Rings, Single Marchal Fog Light Hsg
    I have a full set of silver headlight trim rings for sale, they have a little green overspray on a couple, otherwise nice and straight and in great shape. $45 shipped for the set
    Next is a set of Headlight buckets, modified for H4 headlight housings, can be used with sealed beam, or H4, and a full set of black headlight rings. The black is ok, probably should be re-painted to look perfect.
    $60 shipped for the set
    Lastly, I have one good Marchal fog light housing with good electronics/wiring. There is a dent on the back, but the front is in great shape. Includes mounting lug, nut, and the plug.
    $40 shipped
    May 2017
    Beaverton, Oregon
    Still available
