    FEP Member vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Default Dash Pad mount question
    I am about to start test fitting my new dash pad, in a car where everything was removed, so I have next to no idea how a lot of this was originally fastened to the car.
    In the picture below, I see the metal brackets built into the pad, and I know that screws go up through the tabs on the dash hull, but should there be speed nuts on the dash brackets shown, or do the screws just go up into the dash pad itself?
    May 2017
    Beaverton, Oregon
    I've read through that one, but it doesn't show if there are speed nuts on the dash pad, or how its actually connected there. I have looked at LMR as well, and can't find speed nuts/hardware kits for the dash, and I don't have the old pad to compare it to. Maybe I will call them if I can't find out through pics, etc.
    May 2017
    Beaverton, Oregon
    Looks like in the pictures on this site, I can almost see the speed nuts... so that is what I need to find. Looks like I need 4 of them. They were probably buried in the car when I got it, and who knows where that bag of hardware may have ended up.
    https://www.americanmuscle.com/red-d...6-install.html
