Results 1 to 25 of 35
    FEP Power Member racerxmd's Avatar
    Sep 2007
    Rockville,MD.
    Exclamation New Stroker Build For Racerxmd
    Gathering parts to build a large displacement stroker for my new '85GT T-Top project. Recently got a Great Deal on a Dart 8.2 deck SHP block. I am having Duane Busch at Busch Enterprises in NC build it for me. Block is in route to Duane. Will be ordering the rotating assembly very soon. Will be choosing either a 363 or 376 cu. in rotating assembly. Going to keep it as a Neutral Balance w/ 11 to 1 compression. We are leaning on choosing the 11R head from Trick Flow. It will be the 205 version with 56 cc and the Titanium Retainers. Anyway, here are some of the pics of the new Dart SHP block:
    This will be going in my '85 GT T-Top:
    Apr 2008
    Waikoloa , Hawaii
    Sounds like some good parts. You keeping it N/A?
    1986 CHP SSP Coupe
    Sep 2007
    Rockville,MD.
    yesss
    FEP Power Member Mikestang's Avatar
    Aug 2013
    Firestone, CO
    Beefy base, gonna be sick!
    1986 Ford Mustang GT-
    Not much stock stuff left
    347 NA power, CNC ported heads, Extrude honed Trick Flow Intake, Custom Cam
    Suspension, custom k- member, TQ arm/pan hard rod... Much more
    Restored and ready to race, made to go fast while cornering
    1981 Mustang GT-
    Old SCCA A-Sedan National Champ car
    In the middle of rebuild
    1986 LX Sedan-
    Plans to be determined...
    "Every day I learn how much I don't know"
    Study your desired RPM range vs FPS in relationship to your rings at a given stroke. Make sure you know what you are signing up for.
    Me personally, I'd go big bore with a 3.25" stroke and build for more R's.
    Good luck with your build!
    Dec 2009
    St. louis MO
    That block is so nice and new it almost looks like aluminum. You'll be in good hands with Duane. I haven't heard much from them since the old HC5.0 days.
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
    Sep 2007
    Rockville,MD.
    Little update. My 363 short block is coming together finally:
    Jan 2007
    Quartz Hill, California
    What cam are you going with?
    Robert
    My RS in Action
    Congratulations - looks like it will be a stout piece when it’s done!
    Any HP target in mind? N/A at 11:1 with that much displacement and 205 heads and a decent cam with headers and a good intake I’m thinking you should see 500 lbs of torque or so. More if it’s built well.
    Sep 2007
    Rockville,MD.
    We are using a TFS Stage IV camshaft for this build. The cam specs are as follows:
    Dur = 242*/246* @ .050
    Lift = .595/.595
    Lobe Separation = 110*
    Also have a TFS R-Intake (carb.) going on. Plus my old Pro Systems carb (840cfm) from my old 427 Windsor.
    Our goal is near 600hp and little street use.
    FEP Supporter vdubn's Avatar
    May 2017
    Beaverton, Oregon
    Very nice setup!!
    Sep 2007
    Rockville,MD.
    Little update from Duane Busch. He applied the Glyptal to the lifter valley and timing area infront of the motor. Hopefully the 11R 205 heads will be installed soon. Can't wait! Here are a couple pics:
    That is a stout piece! Can't wait to hear it run!
    Sep 2007
    Rockville,MD.
    Me Too! Haha
    Sep 2007
    Rockville,MD.
    363 Build Album:
    https://imgur.com/a/VKcAd2z
    Sep 2007
    Rockville,MD.
    Sep 2007
    Rockville,MD.
    Sep 2007
    Rockville,MD.
    Sep 2007
    Rockville,MD.
    Apr 2008
    Waikoloa , Hawaii
    Bad ass, keep us posted.
    1986 CHP SSP Coupe
    Sep 2007
    Rockville,MD.
    Mar 2017
    middleboro massachusetts
    gonna be nasty!
    Very nice setup.
    You might want to consider a custom cam from Flow Tech instead of an off the shelf grind. Makes all the difference in a lot of cases.
    http://www.flowtechinduction.com/
    Nice.
