I have an 86 vert, and the yesterday the car started when I went to move it out of the garage, but when I went to move it back in, it just cranked over. I did manage to get it started one last time, to pull it back in, but now it won't start. The FP turns on for a couple second when I turn they key on, but I don't smell gas under the hood, even after cranking for 30 seconds or more. I did check the FP regulator and with the key in the "on" position it reads 20 psi, but it slowly falls back to zero. I also checked the coil, which seems to be fine and know I need to go through the entire electrical trouble shoot check list. It's got a 347 SC in it, with a Vortec T-Rex exdt. FP and I just wanted to see what you guys thought could be the issue.
Thanks in advance!!
