~LES~
157 HP @ 4200 RPM
240 ft/lb @ 2400 RPM
Capri:
I don't have the buck tags or vin plate numbers just vc labels
~LES~
157 HP @ 4200 RPM
Capri:
VIN
9 = 1979 model year
R = San Jose Assembly
14 = Capri 3-dr hatchback
Y = 2.3L engine
611005 = 11,005th 1979 Mercury scheduled for production at San Jose Assembly
Door Tag
Date - 01-79 = January 1979 scheduled build
GVWR - 3664 lb/1661 kg = gross vehicle weight rating
Front GAWR - 1917 lb/869 kg = front gross axle weight rating
Rear - GAWR - 1767 lb/801 kg = rear gross axle weight rating
F0129 = 129 lbs front accessory reserve load
R0001 = 1 lb rear accessory reserve load
Exterior Paint Colors - 1G = Silver Metallic
DSO - 53 = Oakland district
Body - 61D = Capri 3-dr hatchback
Mldg - B4D = [will decode later]
Int Trim - MD = Danbury cloth seating, high-back bucket front seats (M), Medium Red interior color (D)
A/C - [blank] = no factory air conditioner
R - 5 = AM/FM stereo radio with 8-track tape player
S - [blank] = no sunroof
Ax - Y = 3.08:1 axle ratio, non-locking differential
Tr - 7 = 4-speed manual Ford of Germany "Hummer" transmission
VV = front springs
FF = rear springs
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
VIN
1ME = Mercury vehicle manufactured in USA
B = active belts, no airbags
P = passenger car
68 = Capri GS 3-dr hatchback
F = H.O. 5.0L V8 engine
1 = VIN check digit
C = 1982 model year
F = Dearborn Assembly
617312 = 17,312th 1982 Mercury scheduled for production at Dearborn Assembly
Door Tag
Date - 02/82 = February 1982 scheduled build
GVWR - 3940 lb/1787 kg = gross vehicle weight rating
Front GAWR - 2081 lb/943 kg = front gross axle weight rating
Rear - GAWR - 1882 lb/854 kg = rear gross axle weight rating
F0109 = 109 lbs front accessory reserve load
R0115 = 115 lbs rear accessory reserve load
Body - 61H = Capri GS 3-dr hatchback
Int Trim - EA = leather & vinyl seating, low-back bucket front seats (E), Black interior color (A)
R - 7 = AM/FM stereo radio with cassette tape player
S - [blank] = no sunroof, no T-roof
Ax - Z = 3.08:1 axle ratio, Traction-Lok (limited slip) differential
Tr - 4 = 4-speed manual Tremec "SROD" transmission
RR = front springs
HH = rear springs
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Thank you foxchassis
~LES~
157 HP @ 4200 RPM
Capri:
82 has a t roof. I didn't see it mention anything about a t roof it just says blank no sunroof. Now where would it say it came Factory with the T roof
~LES~
157 HP @ 4200 RPM
Capri:
Here's a pic of the car.
~LES~
157 HP @ 4200 RPM
Capri:
If the T-roof was an ordered option through DAP it would have a "D" code under the "S" (sunroof) column on the door tag. If that column is blank that means the T-roof was an aftermarket or owner installation.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
