I’m on my second one that’s failed. If I unplug it, does it affect anything else?
1984.5 GT 5.0 5 Speed ANALOG
BBK Long Tubes/H pipe/FM
Edelbrock Intake/Holley 600
8.8 w/FMS 3.73s
Steeda Shifter
2010 GT 5 Speed DIGITAL
Track Pack
Pypes Violator axle back
Airaid Cold Air
8.8 w/FMS 3.73s
Steeda Shifter
Track Pack
Airaid Cold Air
I think the better question is WHY do they keep failing?? It sounds like there may be a bigger problem.
Well that would normally be my concern, but for something as insignificant as an idiot light, I'm not too worried. I figured my first one would just go on too early and sometimes stay on because its a 32 yr old part. The second one was new old stock of about the same vintage and only lasted a year before it just stayed on all the time.
I was just wondering if I unhook it, it will affect anything else.
8.8 w/FMS 3.73s
Steeda Shifter
Track Pack
Airaid Cold Air
Also, does the "DOWN" refer to anything? Because mine was laying horizontal.
8.8 w/FMS 3.73s
Steeda Shifter
Track Pack
Airaid Cold Air
Never seen that before...is that part behind the warning cluster? If so...I would guess no repercussions from unhooking it. It doesn't look like anything I have seen back at the tank near the actual sending unit? My '82 GT has the idiot light on all the time and I just ignore as my gauge still works.
Jason Smith
MCA #65481
'82 Capri RS Resto-Mod
'05 S-281 Mineral Grey
The low fuel warning module should be attached to the back side of the passenger side instrument panel.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
Correct. If you take out the glove box and reach up to the left its right there. I get a kick out of how huge it is to enable such a simple function. 80's tech really just based on 70's tech. Reminds me of how an iPhone is more powerful than Norad circa 1969.
So, Fox, do you know if it affects any other functions?
8.8 w/FMS 3.73s
Steeda Shifter
Track Pack
Airaid Cold Air
It is only for fuel level warning.
Low Fuel Warning Switch Circuit
Improper operation of the low fuel warning system will be apparent when the indicator lamp remains On continually with more than 1/4 tank of fuel or if the indicator lamp remains Off when the tank is empty. If either condition exists, be sure the wiring connector is fully engaged in the low fuel module. Be sure the fuel sender connector is connected to fuel sender. If this does not correct the problem, proceed with the following:
Disconnect the wiring connector attached to the low fuel warning switch. With the ignition On, test the terminal connector positions of the wiring harness connector as follows:
Position 1: Blank, no terminal.
Position 2: Connect a test lamp between terminal and ground. Test lamp should blink. If lamp does not blink, check the following:
- With ignition Off, continuity should exist between pin two and the fuel sender hat terminal. If this is open, check wiring.
- Fuel gauge inoperative: caused by open winding within fuel gauge.
- IVR inoperative: If this occurs, no gauges function.
Poistion3: With ignition On, connect test lamp between terminal and ground. Test lamp should blink and be brighter than position 2.
- If test lamp does not blink, check IVR.
- If test lamp works, but is not brighter than position 2, check wiring for open circuit between terminal two and hat side of the fuel sender connector.
Position 4: Connect test lamp between terminal and positive battery terminal. Test lamp should glow and remain On.
- If lamp does not come On, check for open circuit between pin four and ground.
Position 5: Connect test lamp between terminal and ground. Test lamp should glow and remain On.
- If lamp does not come On, check warning lamp fuse in fuse panel. If fuse is OK, check wiring between terminal five and warning lamp fuse.
Position 6: Connect jumper wire between terminal and battery positive terminal. Warning lamp should glow and remain On.
- If lamp does not come On. replace warning bulb.
If all of the above tests prove OK, replace the low fuel warning module.
Position 1: Blank
Position 2: To Sender - Light Blue
Position 3: IVR to Gauge - Black/Light Green Dots
Position 4: Ground - Black
Position 5: Ignition Switch - Red/Yellow Hash Marks
Position 6: Warning Lamp - Yellow/Black Dots
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Thanks for that info. I was lucky enough to find another NOS switch for pretty cheap. If that one doesn't work, I'll give the troubleshooting a go...or just leave it off. It just irks me to have an option not work!
8.8 w/FMS 3.73s
Steeda Shifter
Track Pack
Airaid Cold Air
New one in and so far no light. Hopefully this one lasts.
8.8 w/FMS 3.73s
Steeda Shifter
Track Pack
Airaid Cold Air
