Results 1 to 9 of 9
    Mar 2017
    middleboro massachusetts
    Default 1985 gt door tag decode?
    Img_9511
    Mar 2017
    Do you have a buck tag for this car? (It is sometimes hidden so look closely.) Do you have a carb tag or an engine calibration sticker (on side of factory valve cover)? Do you have a window sticker, owner card, or build sheet? How many miles on the odometer? Does it have any of the following options?
    air conditioning
    cruise control
    light group (under hood light, buzzer when exterior lights on, etc.)
    power lock group (power door locks, remote hatchback release)
    power side windows
    premium sound system (if so will say "Premium Sound" on factory radio face plate, if not will say "Electronic" on factory radio face plate)
    rear window defroster
    tinted glass (brown or blue tinted upper band on windshield and slight green tint to side and rear glass)
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Mar 2017
    i do have the buck tag.cant get to it until saturday.thanks though!
    Mar 2017
    It does have a/c,power windows,under hood light,power gas door,power door locks,power hatch,rear defrost and cruise control.it does not have tinted glass
    VIN
    1FA = Ford vehicle manufactured in USA
    B = active belts, no airbags
    P = passenger car
    28 = Mustang 3-dr hatchback
    M = H.O. 5.0L V8 engine
    6 = VIN check digit
    F = 1985 model year
    F = Dearborn Assembly
    141691 = 41,691st 1985 Ford scheduled for production at Dearborn Assembly
    Door Tag
    Date - 12/84 = December 1984 scheduled production
    GVWR - 4051 lb/1837 kg = gross vehicle weight rating
    Front GAWR - 2137 lb/969 kg = front gross axle weight rating
    Rear GAWR - 1934 lb/877 kg = rear gross axle weight rating
    F0024 = 24 lbs front accessory reserve load
    R0051 = 51 lbs rear accessory reserve load
    Exterior Paint Colors - 9L = Oxford White
    DSO - 22 = Charlotte district sales office
    Body - 61B = Mustang 3-dr hatchback
    Int Trim - PA = cloth Articulated Sport seating (P), Charcoal/Grey interior color (A)
    A/C - 1 = Dark Charcoal hood stripe, Medium Charcoal "Mustang GT" hatchback decal
    R - 6 = electronic AM/FM stereo search radio with cassette tape player
    S - C = flip-up open air roof (sunroof)
    Ax - M = 2.73:1 axle ratio, Traction-Lok (limited slip) differential
    Tr - 2 = manual Borg Warner transmission (5-speed overdrive T-5)
    BB = front springs
    BB = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Mar 2017
    here is the buck tag.
    MUSTANG = Mustang model line
    MO = moonroof (sunroof)
    053_ = body & paint rotations #053_
    9L = Oxford White exterior paint color
    DF
    ST
    AC = manual air conditioner
    04 = YES rear defrost, YES rear wing
    HB = heated backlite (rear defrost)
    S = speed control (cruise control)
    GT = GT model/trim level
    WD = power side windows (W), power door locks (D)
    MBW = manual Borg Warner transmission (5-speed T-5)
    01 = no hood scoop
    EL
    A = Charcoal/Grey interior trim color
    04
    1
    X
    2 = solid roof/sunroof door with power locks and/or power windows
    NLR
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Mar 2017
    Sweet! Thanks!
